Help needed with board install
Well, I'm nearly finished installing my 100 watt plexi board in my reissue and have a couple of questions. Concerning the wire from the power transformer to the 27k resistor, I have 2 wires coming from the Dagnall PT leftover when I removed my old board, a single green wire from one side and a white wire coming from the group of wires on the other side. Do I connect the white wire and ground the green wire? Also I have a brown wire and a black wire from my pcb effects loop that I need to connect to the new board. Where do I connect these? As you can tell I'm pretty new to this so Thanks for any help you can give me!
- VelvetGeorge
- Site Owner
- Flames1950
My schematic shows four wires going to the effects card PCB.
One (labelled W4, hopefully on the effects card right next to the wire it's labelled the same) goes from the treble pot to the effects card, your signal input. One labelled W3 (again, hoopefully the card has it labelled the same) goes from the card to the phase inverter input coupling cap, a .022uF cap.
The remaining two wires are power into the card from the looks of it. W1 comes off a 47K resistor being fed from the big filter cap cans. W2 will be a ground I presume; I can't see a specific spot on the schematic for where in particular it may ground to.
Since there are no color codes labelled on the schematic, but there is a drawing of the card to show where the connections are, W4 is at the corner of the card closest to the "level" and "bypass" buttons; W3 is right below it (more towards the center of the chassis.) W1 is on the edge of the card across from those buttons, and W2 is in the corner across from the jacks.
Hope I'm helping and not confusing the issue!! I also don't know if the 47K resistor that supplies power to the effects card was on the original PCB or came off the filter caps; if it was on the PCB and not accounted for in the kit you'll have to add it and insure that it doesn't short out anywhere.
I can try to e-mail the schematics of the amp and effects card if you need 'em.
i also have a topic going on the effects card,but i plan on removing mine.im thinking i can just remove 3 of the wires and keep the one that is coming off the master volume.just feed the new board with this wire instead of feeding the effects card.this sound logical?the 47k resister and trace isnt on non reissue boards from what i can see.Jason
