New! 1969 Steel Chassis for Stand-up PT
Get your DIY parts info here!
Moderators: VelvetGeorge, BUG, ValveStorm
ValveStorm
Supporting Advertiser
Post by ValveStorm » Sun Apr 26, 2015 2:45 pm
Just got a batch of new 1969 style SuperLead chassis. These are similar to the ones that came with the MetroAmp 1969 kits, except they are made from steel (not aluminum). They also have the extra hole on the front for folks that want to incorporate the polarity switch, as well as holes on the back that can be used for an FX loop, etal.
Re: New! 1969 Steel Chassis for Stand-up PT
Post by neikeel » Mon Apr 27, 2015 12:09 pm
ValveStorm wrote:Just got a batch of new 1969 style SuperLead chassis. These are similar to the ones that came with the MetroAmp 1969 kits, except they are made from steel (not aluminum). They also have the extra hole on the front for folks that want to incorporate the polarity switch, as well as holes on the back that can be used for an FX loop, etal.
Excellent, might need one of those soon...............
MiniMajor
Post by MiniMajor » Mon Oct 19, 2015 3:25 pm
Hey all,
Looking to pull the trigger on the new '69 chassis. But, is there someone who can/does make metal panel plates for this chassis with a polarity switch and four output jacks? Here's to hoping.
Thanks,
Hale
Everything sounds better with volume!
ValveStorm
Post by ValveStorm » Thu Oct 29, 2015 1:59 am
We can have metal plate made for this chassis, but:
1) They are expensive... about $120 per set
2) The maximum wide of the material is 24 inches. A typical back plate is 25 inches.
