Post
by sah5150 » Sun Jun 06, 2010 11:01 pm
Alright... got my tubes and started testing...
Throughout the below process, I found some mistakes and fixed them.
First I put in the preamp tubes and plugged in the amp. Measured 120.4 VAC at the live terminal of the IEC socket and the power switch. Good...
Flipped on the power switch... Preamp tubes light up... Measured between 6.1-6.2 V DC heater voltage on the preamp tubes measured from pin 4 to pin 9. Seeing 3.3-3.4 VAC on pin 2 and 3.5-3.6 VAC on pins 7 of the EL34s... A bit high, but ok...
Checked Pin 5 of each EL34 and found -51V... Ok...
Turn the amp off, drain the filter caps. Put in the EL34s... Threw the power and standby switch on... Starting taking measurements...
V5 EL34 Pin 2 - 3.315 AC, Pin 3 - 460.5, Pin 4 - 458.8, Pin 5 - -40, Pin 6 - 458.6, Pin 7 - 3.485
V6 EL34 Pin 2 - 3.336 AC, Pin 3 - 460.5, Pin 4 - 458.8, Pin 5 - -40, Pin 6 - 459.6, Pin 7 - 3.52
V7 EL34 Pin 2 - 3.364 AC, Pin 3 - 460.3, Pin 4 - 458.6, Pin 5 - -40, Pin 6 - 460, Pin 7 - 3.562
V8 EL34 Pin 2 - 3.388 AC, Pin 3 - 460.6, Pin 4 - 458.7, Pin 5 - -40, Pin 6 - 459.5, Pin 7 - 3.625
Ok, time to bias the EL34s... I've got 1 Ohm 5 Watt resistors from pin 8 to pin 1 to ground. Check V5 and pin 1 and adjust the bias pot, mess with it a bit and I get:
V5 EL34 34.8 mV
V6 EL34 33.1 mV
V7 EL34 36.6 mV
V8 EL34 37.5 mV
Ok, good enough...
My relay power supply is measuring 6.085 VDC and I get the same reading at the coil of each relay, so it looks like the relay supply is working...
None of my switching LEDs is lit though... Flipping the manual switches doesn't light any of them... Hmmmm.... Start checking some of the manual switches - definitely something wrong with the switching...
Troubleshooting continues...
Steve
sah5150 on Mon Jun 07, 2010 1:52 am, edited 2 times in total.
