As I´m a new builder planning my first build, I want to answer a few questions for myself before grabbing the soldering iron:
I bought the Metro spec Heyboer 1203-80-ML (laydown) PT:
This PT groups heaters, heater CT, high voltage terminals and PT CT together on one side. On the other side we have primaries (120V, 220V, 240V), PT common (orange) and BIAS taps.
I found that this configuration is different from what most builds with laydown mount PTs use: on most laydown PTs high voltage terminals are alone on one side, all other connections on the other side. This allows for short wire runs. Here is the tranny George uses on his 12xxx builds showing that configuration:
![Image](http://dl.dropbox.com/u/18415326/JMP100%20build/12xxx%20laydown%20PT%20wire%20dress-skaliert.jpg)
If I install my PT the "traditional" way, with heaters facing power tube sockets - this will cause extra long wire runs for high voltage terminals (to stdby switch) and primaries (to voltage selector I´ll use). Like in this picture of an amp using the exact same tranny I bought:
![Image](http://dl.dropbox.com/u/18415326/JMP100%20build/wire%20dress%20Heyboer%20laydown%20-%20Metro%20thread-skaliert.jpg)
So - my question is: Could I install the tranny 180 degrees rotated (heater taps facing power switch instead of power tube socket side) which would allow for shorter wire runs (with exception of the heaters and heater CT)?
Would it be a good idea - or would it for some reason cause problems to flip the tranny?
Also - does anybody have a picture of my type of PT used in a 69 100W SL build with good wire dress?? Since I´ll use the Metro instructions - and these use the standup type PT, I´m very curious how I should best route the wires from my laydown tranny (actually all the wires) for maximum hum suppression and to avoid ghost notes etc.
Any suggestions would be very appreciated
Greetings
YF
