Anyway, for this build (4 gainstage, w/CF) every tube has its own filter cap, I also have seperate caps for screens, PI & mains.. the idea is that all grounds go back to the appropriate filter return, these are then tied together in order and grounded at one point (sounds familiar eh). Im just drawing out a layout before I wire up the mainboard & Im not too sure if the master volume ground & treble will return to the ground of the cathode that drives the tonestack (which will then tie to that stages filter) OR if I should be grounding them at the PI filter (as they are feeding the PI).
Im using a jose master style layout, 10k res, .22, diodes & master then onto the tone controls. Im also fitting a Metroamp FX loop to this build, im planning to just ground that to the return of the PI filter that feeds it. One other thing, should the power tube cathodes go to mains or screens return? Im thinking mains?
Anyway, heres a couple of shots of what I have so far. Early days, but the power section is done & tested (I replaced the enameled copper bus for tinned stuff.. once I figured out you cant solder onto enameled copper, not easily anyway lol)
Cheers, Chris.
