Guys, this is my 1st attempt on drawing a layout.... the thing is that I've used 3 schems for this and haven't brought them together as a unique schem yet, but the layout it here as follows.
It's a 18w 6v6 amp with one plexi-like channel and one higain channel copied from the bogner triple giant preamp sharp channel that I"ve found on the net. The poweramp is from Mark Huss 6v6 plexi schem, as the power supply.
Sorry the about the mess, but can you see anything wrong in a first glimpse? Will post the schem asap
1st attempt - project layout
93' Fernandes SSS strat
93' Fender Japan HSS Strat
Re: 1st attempt - project layout
To see anything wrong is hard without a schematic. A little tip is to use shielded wire from input to tube and place the resistor right up the tube socket. This will give you less noise.
What also pulls my attention in the layout is the "floating" resistors on the output tube sockets. If you use the resistor wires as connection, make sure to use a heatshrink around it.
Thanks for the tips!!! Wrote down on my notebook
I'll post the schem soon, just finishing the mix.....
