Big problem in Fx Loop
raza
Post by raza » Wed Jan 27, 2016 12:38 pm
Hi !
I have finish a new amp but I ve a problem with the Fx loop.
The fx loop can be switch. When the fx loop is on, I have a noise and when I UP more than 12 oclock the power in level, The amps starts to CRY and make lot of noise (OSCILATION NOISE).! :what: :what: :what: :what: :palm:
What can I do? The tube si a Tung sol 12ax7.
How I can reduce the signal?
subir fotos a internet
raza
Re: Big problem in Fx Loop
Post by raza » Wed Jan 27, 2016 12:45 pm
The power in level Pot is a 250ka pot, same value for VOL pot. :wink:
danman
Post by danman » Wed Jan 27, 2016 4:24 pm
Since you mentioned that it was a new amp, did you try to play it before installing the loop? The reason I ask is that it is common to have to swap the OT primary wires on new builds that exhibit this same problem. Usually swapping the wires going to pin 3 of the power tube sockets will fix the problem.
raza
Post by raza » Thu Jan 28, 2016 1:55 am
Hi,
It'snt problem from the wires of the Ot becouse when I Switch off the Fx loop, I bypass ther return Stage, and it sounds very good.
Also I test to put the guitar for the return, And the amp sound good, only with the power in Level.
I dont know whats happen....
danman
Post by danman » Thu Jan 28, 2016 4:13 pm
Ok, just wanted to check that first. I don't have much experience with the loop so hopefully one of the fellas will have some suggestions.
