Post
by shakti » Sun Feb 14, 2016 2:20 am
I'd appreciate any discussion on this circuit. I know other forum members have built 18w amps, and there is a dedicated community/forum for 18w builds elsewhere, but there has never been much discussion on them around here.
One thing I am pondering is how much to stray from the original layout/circuit, especially with regards to grounding. These amps are notorious for issues with the tremolo especially, and grounding seems to be a big part of it. With my other Marshall clones I've used "Larry" grounding exclusively, but with this amp, being somewhat of a restoration as well, I am not sure how much I want to stray from the original scheme. The original used a ground buss across the back of all the pots (even running through the input jacks), and the grounds from the board were attached to that buss in a somewhat random pattern. The layout of the preamp tubes, with the phase inverter as the middle of the three preamp tubes, doesn't exactly help. On the original, the preamp filter cap (which supplies all the preamp tubes incl the phase inverter), is grounded along with the power tube cathodes, for instance. OTOH, I have read elsewhere that going to a star grounding scheme can actually cause even more problems with the tremolo channel, so I am a little unsure what to do.
One very common mod is to use shielded wire for the grids to the preamp tubes, and I think I will try that. I forgot how this is done...I use the shield to ground on the input jacks, but not by the preamp sockets, is that right?
I have nearly all the parts I need, except the pots, knobs and a tiny few bits and pieces. Most of it I can get from Valvestorm, but there are a few where I would love to find NOS parts, so if anyone can help me out with the following I would be very happy! Trades or cash paid...
1 x 2.7M Piher or NOS carbon comp 10%
2 x 68k Piher 5%
1 x 125R 5w Radiospares (for the power tube cathodes...but do I really need such a high wattage resistor??)
1 x 1.5k 5w(?) Radiospares (for the voltage drop/decoupling resistor between the two sections of the filter cap)
And lastly, the original can holder is a small diameter, and it is impossible to find a modern 16+32uF replacement that fits. I either need to change the cap holder to a larger diameter (and probably have to drill new holes which I don't want to), or find a NOS 16+32 that fits. Anyone who can help?
