Another TAD Super Lead build
Prowler
Re: Another TAD Super Lead build
Post by Prowler » Sat Nov 26, 2016 10:07 am
Prowler
Post by Prowler » Sun Dec 04, 2016 5:17 am
Prowler
Post by Prowler » Sat Dec 10, 2016 10:04 am
Today I soldered pots. Tomorrow I am going to do tube sockets and input jacks.
https://www.dropbox.com/sh/zxkbecye3paz ... l4fSa?dl=0
Prowler
Post by Prowler » Sat Dec 17, 2016 6:52 am
Prowler
Post by Prowler » Wed Dec 28, 2016 8:17 am
I think the amp will be finished tomorrow and I will post some pictures then.
Prowler
Post by Prowler » Thu Dec 29, 2016 7:02 am
Now the amp is finished! :champ:
I am going to inspect the wiring once or twice before I connect the amp to a dim-bulb tester.
https://www.dropbox.com/sh/hbo9mjjw38dq ... YKDYa?dl=0
danman
Post by danman » Fri Dec 30, 2016 1:12 pm
Congratulations Prowler! Looks great! I bet this build went much easier than the first one didn't it?
Prowler
Post by Prowler » Fri Dec 30, 2016 4:03 pm
danman wrote:Congratulations Prowler! Looks great! I bet this build wentmuch easier than the first one didn't it?
Hello my friend! This build went much much easier than my first. It means a lot to me when you say that the build looks great. I better start reading though all your tips you gave me for firing it up with a dim bulb tester. I tried to Larry ground this one right from the start and I think I will try Michael/RT''s one wire mod once again.
Prowler
Post by Prowler » Tue Jan 03, 2017 11:09 am
I took some measurings today with only the preamp tubes installed. The amp was connected to a dim-bulb limiter while measuring.
https://www.dropbox.com/sh/at3f7nhew09w ... 8KFPa?dl=0
danman
Post by danman » Tue Jan 03, 2017 4:51 pm
Everything looks good. Voltages should come up when you remove the dim bulb tester. Congratulations!!
Prowler
Post by Prowler » Wed Jan 04, 2017 1:43 pm
danman wrote:Everything looks good. Voltages should come up when you remove the dim bulb tester. Congratulations!!
Thank you my friend! I just got the amp working and it sounds good. I played for an hour trying all the inputs and controls which seem to work fine. It was pretty quiet too when not playing.
The standby switch gave a loud pop when I was turning off the amp. I guess I will have to remember to turn all the volume knobs down or is there a way to fix this?
I think I will install the PPIMV before recording any clips.
danman
Post by danman » Wed Jan 04, 2017 4:59 pm
You can place a capacitor across the standby switch to help prevent the pop. I can't remember the value but you can probably find it with a Google search.
Prowler
Post by Prowler » Sat Jan 07, 2017 12:17 pm
I installed the PPIMV:
https://www.dropbox.com/sh/v2elinm1gm23 ... OQ14a?dl=0
The amp needs more gain! :lol:
I think I will try the one-wire mod next.
