Please help me out. 1969 100w build
no0sand1s
Post by no0sand1s » Sat Apr 21, 2018 9:51 am
Hello all. I recently completed assembly of a 1969 100W amp and am during initial testing, I'm getting unusual readings on my meter for voltage on the tube sockets. I obtain 3.47VDC for measurements on pin 2/7 of V4, V5, V6, and V7 and have adjusted the bias trim pot to obtain -49VDC - these are fine!
Check out the photo link - the photo of the chart shows unusual readings when testing each pin.
If anyone has ideas where to take a peek or sees anything I missed, please let me know. If additional photos are necessary, please advise. Here's a link to photos: https://www.flickr.com/gp/wedinbordeaux/045Ah2
no0sand1s
axeman
Re: Please help me out. 1969 100w build
Post by axeman » Sat Apr 21, 2018 5:40 pm
OK whats the problem, those readings are normal.
Post by neikeel » Sat Apr 21, 2018 7:29 pm
Your heater voltage is a smidge high, but no load is ok
What selector are you using and your wall voltage?
Build looks fine to me, suggest you post the rest of your voltages before you put your tubes in.
danman
Post by danman » Sat Apr 21, 2018 9:13 pm
Pins 2 and 7 are the heater filament pins so you should be reading AC voltage there. Like the fellas mentioned above, your measurements look fine. A couple extra volts at the wall outlet will cause readings to be slightly higher than expected as will testing without tubes installed.
no0sand1s
Post by no0sand1s » Wed Apr 25, 2018 11:27 pm
Everyone - thanks for looking.
Please see the photo of the voltage chart (via my link) showing negative readings/vast differences in what the voltage should be vs. what I'm reading (213v vs -.6 on pin 6 of V1, 168v vs .73v on pin 1 of V2, etc.)?
Post by neikeel » Thu Apr 26, 2018 2:09 pm
Ah it would not open on Flickr before.
Yes you have a problem, your heater chain is odd between power and preamp and the HT rail is missing in action on way to v1
no0sand1s
Post by no0sand1s » Sat Apr 28, 2018 2:18 pm
The readings I've posted on the chart in my photos are not normal.
Kindly check out the photo link - the photo of the chart shows unusual readings when testing each pin.
If anyone has ideas where to take a peek or sees anything I missed, please let me know. If additional photos are necessary, please advise. Here's a link to photos: https://www.flickr.com/gp/wedinbordeaux/19r7my
no0sand1s
no0sand1s
Post by no0sand1s » Sat Apr 28, 2018 2:20 pm
no0sand1s
Tazin
Post by Tazin » Sat Apr 28, 2018 4:54 pm
Your flickr page says, "You need to be signed in to see this". Additionally, it states, "It appears you don't have permission to view this album". Perhaps you need to change the album settings so general viewing is allowed.
no0sand1s
Post by no0sand1s » Sat Apr 28, 2018 11:10 pm
thanks for letting me know. updated now. https://www.flickr.com/gp/wedinbordeaux/19r7my
Tazin
Post by Tazin » Sun Apr 29, 2018 11:48 am
For some reason I still get the same error. I can view the iPhone & Weddin' albums and photos.
no0sand1s
Post by no0sand1s » Sun Apr 29, 2018 1:55 pm
Ugh. Flickr has a mind of it's own. Try this: https://www.flickr.com/gp/wedinbordeaux/19r7my
Tazin
Post by Tazin » Sun Apr 29, 2018 5:02 pm
The Flickr page works for me now. First off, a decent amount of the solder joints look terrible...They do not have that nice "flow" look to them. I also noticed that some pictures show a full potentiometer buss ground wire while others show it as piece-meal?...Which ground scheme are you using? Additionally, I did not see a voltage chart among the photos?
Tazin
Post by Tazin » Sun Apr 29, 2018 6:01 pm
You've got a long piece of solder or a component lead cut off laying on V4. Also, the black heater wires at V2 are a bit long at the solder joint so you may want to cut the excess off. Why do you have two yellow wires at the 8K2 2watt B+ dropping resistor?...Are you feeding the 10K & 8K2 2watt resistors backwards (reverse order)?
no0sand1s
Post by no0sand1s » Tue May 01, 2018 10:15 am
Thanks Tazin. I've gone through all solder joints as you suggested. The 2 yellow wires to the 8K2 2W resistor are from V4 pin 6 and the F3 capacitor, depicted in assembly instructions here, step 13
http://valvestorm.com/sites/default/fil ... MP_KIT.pdf
I'm using a modified grounding scheme found here:
https://drive.google.com/drive/folders/ ... EFwZHpXN3M (version #6). I intend on adding the PPMIV when the amp is working.
New link to see updated photos (conflicting photos removed), voltage chart (1st photo) still showing odd numbers. https://www.flickr.com/gp/wedinbordeaux/3ta970
