![Cool 8)](./images/smilies/icon_cool.gif)
67' 1986 board
- Flames1950
No, the way you're doing it is not "wrong" -- my own builds do it the same way you do.
The way George's picture shows is much more stable however -- the pot will be installed rock solid with support all around. The way you and I have used works fine but the pot does kind of "float" and move a bit when you're adjusting, and probably takes a little vibration when the amp is transported.
![Image](http://i32.photobucket.com/albums/d2/BlueFlameAmps/BlueFlameSignature2.jpg)
- Flames1950
- Flames1950
- Flames1950
People have been claiming that carbon tracks in bias pots can go bad for years. How many Fenders do you see with replaced bias pots? I've yet to see one. Besides, the wiper on that bias pot is all one plate with a lug on each end -- there's nothing to go bad, it's still a solid piece between the turrets.
Darrell,
Dude it is the same. You say toMAYtoe and George says toMAHtoe. The electrical connections are the same. resistor to one lug and the capacitors to ground and other lug. The picture you are posting have the same connections to the pot as Georges method. Also it really seems like you are taking this all personal.
~CS
~CS
- Flames1950
