Hey guys I'm going to be building a new amp soon, and I like making my own boards so I can adjust the layout. The metro circuit board terminals these look sweet and are less expensive than keystone or hoffman turrets. My question is how easy/difficult is it to stake them in XX phenolic? Do use the standard turret tool or something else?
Ben
Question about staking metro terminals
I've wondered the same thing. I've read you can use the standard staking tool but I don't understand how it would work??
Single turrets have the ridge that rests on the frontside of the board so that when you flare the turret on the backside it holds it tight in the hole. From what I can tell from the pic, there's no flared ridge so I don't see what would prevent the turret from pushing through the backside of the board other than the component lead that you'd have soldered to it.
- el34on11
The Metro turrets don't need to be staked, but you need to drill the exact size hole and press them through...Even tho it says 1/8" I found that 1/8" hole is a bit too big for a nice tight fit. I use a machine screw size 32 drill bit and that gives you a nice tight fit.
Hope that helps you
Derrick
Hope that helps you
Derrick
LesPauls and Marshall's
- VelvetGeorge
- Site Owner
- wdelaney72
George's split turrets are the best option out there... regardless of cost. They instll the esiest and they are the most flexible in that they have the hollw center.
I've staked these with a homemade staking tool similar to Hoffman. I've also used Keystone's staking tool, as well.
Walter
