NOS Mustard Orientation
- Flames1950
- S.Marshall
- gutpile
Different manufacturers? are they both phillips? is there any difference tonally? the lacquered ones are more sought after I presume?lifer wrote:the difference in appearance is because... different manufacturers.
the 'laquer' coating can no longer be used because the worthless EPA
says it "dangerous"-----------
Metro Clips
caps orientation
gutpile------------
no- they're not all Philips. they are both "laquered".
I have lots of philips and mullards........i can't say i ever noticed a
difference. That's just me, though.
mustard orientation
yeah............
I got opinions about government. I'm quite knowledgeable.
The EPA is pure B*******. You're not going to die from drinking
water or breathing air.
I agree with Aiken Amps...
There is not "too" much difference in sound, in a guitar amp.
The noise floor is so high and the added benefit of noise rejection from orientating the cap is hard to notice, especially in a band situation.
However it is better to observe polarity if you know the orientation, that
http://www.sozocapacitors.com" onclick="window.open(this.href);return false;
- S.Marshall
[quote="SoZo"]I agree with Aiken Amps...
orientation
hey----you learn something new everyday, huh??
thanks sozo!
thanks sozo!
- S.Marshall
Re: orientation
I sure try to.lifer wrote:hey----you learn something new everyday, huh??
- 54strat
I found some info that states that for non-polarized caps, when reading the value the inner foil is on the right side. That's great for mustards that have the value info printed long ways, but for some of the caps like in the photos on page two of this thread, where the info is printed around the circumfrence of the cap instead of long ways (does that make sense?), it didn't say. The thing I found also stated that for coupling caps the inner foil should go to the grid of output tube and the outer foil should go to the plate of driver tube.
I don't remember where I found the info...I just jotted it down. Might have been Hoffman or Aiken Amps sites. Maybe someone who has scoped mustards can confirm.
73 Marshall 1987
76 Marshall 1936 cab w/Celestion V-30's
54 Fender Stratocaster hardtail
87 Fender Stratocaster
- Ricky Lee
It's my understanding that the Sozo caps should be oriented with the ring/band toward the tubes.
- gutpile
FWIW I put them in all the same way not knowing which way is right, and it is quiet as ever as sounds amazing!!
Metro Clips
cap orientation
so which way should my Sozo's go?
which way should my mustards go?
I'm lost man
I'm lost man
