icar 100K pot
Fever Dog
icar 100K pot
Post by Fever Dog » Tue Oct 13, 2009 2:33 pm
i just replaced the icar pot in my late 60's/early 70's vox wah. it say 100k on the pot. however, i checked it with a mutlimeter and measured 500k. has anyone else found this?
http://www.myspace.com/bigterrible" onclick="window.open(this.href);return false;
V8
Re: icar 100K pot
Post by V8 » Tue Oct 13, 2009 8:37 pm
They tend to drift up over time and I think how much usage it has seen . I have two old Vox wahs, ICAR in one measures 190K ohms and the other 290K
Freedom
Re: icar 100K pot
Post by Freedom » Wed Oct 14, 2009 4:47 am
Mine measures 241k (it says 100K on the pot like yours)...
Freedom of Music <=> Music of Freedom
Fever Dog
Re: icar 100K pot
Post by Fever Dog » Thu Oct 15, 2009 12:51 am
wow. thats nuts. it never even occurred to me that it could have drifted that much.
V8
Re: icar 100K pot
Post by V8 » Thu Oct 15, 2009 10:30 pm
Carbon resistors can drift up over time as well . Usage wears the resistive carbon track which IIRC will also contribute to this increased resistance. Notice that some of the replacement ICAR pots are 200K to replicate an old used wah pot.
michele
Re: icar 100K pot
Post by michele » Thu Jul 25, 2013 12:49 pm
I resume this long gone post to discuss with you about old icar pots. I've got one of the first clyde mc coy wah from 1967 it has epoxy on the circuit to hide it. It works but the pot is a little scartchy. So i bought a replacement from Rmc. Then i replaced it and measured... Well it drifted to 6.2 M! :what:
When i replaced it with the rmc one.. The wah didn't work well. The effect was very weak.. So i don't know what to think.
My thec told me that according to him it was way more than 100k till the start. Maybe 2or 3 M. It was written 100k to create confusion.
V8
Re: icar 100K pot
Post by V8 » Thu Jul 25, 2013 3:57 pm
6.2 M ! Sounds like the pot is shot. Good to grab a few to try , tapers seem to vary...
michele
Re: icar 100K pot
Post by michele » Thu Jul 25, 2013 4:43 pm
I re istalled the icar one.. Amd the sound is there! Jimi for sure!
I don't understand ... :help:
axeman
Re: icar 100K pot
Post by axeman » Thu Jul 25, 2013 8:42 pm
Fever Dog wrote:i just replaced the icar pot in my late 60's/early 70's vox wah. it say 100k on the pot. however, i checked it with a mutlimeter and measured 500k. has anyone else found this?
What did your wah sound like before it started giving you problems?
michele
Re: icar 100K pot
Post by michele » Fri Jul 26, 2013 3:23 am
Hi the wah was wonderfull but the scratchy pot..
Haze13
Re: icar 100K pot
Post by Haze13 » Fri Jul 26, 2013 5:48 am
In that case may be there is an option to clean the pot? Sounds stupid for a 45 years old pot, but there is always a hope :)
axeman
Re: icar 100K pot
Post by axeman » Fri Jul 26, 2013 8:44 am
I ask because maybe that famous sound we are after is truly coming from the 500k pot and not the the so called 100k. :scratch:
michele
Re: icar 100K pot
Post by michele » Wed Aug 21, 2013 3:15 am
axeman wrote:I ask because maybe that famous sound we are after is truly coming from the 500k pot and not the the so called 100k. :scratch:
I think the same thing... How is that with 200k the wah doesn't sound a t all!??
Haze13
Re: icar 100K pot
Post by Haze13 » Thu Aug 22, 2013 3:07 am
Can you post some pics of this wah with a 6.2 M ohm pot?
Wah does not need all that range of a pot, It uses actually some small portion of the "trace" of the pot. May be the 6.2 M Ohm pot is a special LOG type or something like it, and when the Wah at max, you get only like 200k-300k of a resistance? Can you check the resistance when the wah on the max?
appetite4distortion
Re: icar 100K pot
Post by appetite4distortion » Fri Aug 23, 2013 2:14 pm
6.2M seems me crazy (or shot), possibly you measured in the wrong way? did you measured when the pot was desoldered and alone?
BTW, yes, it's normal for them to drift from nominal 100K to two or three times..mine (68) is around 300k, don't remember exactly.
Unfortunately it is also normal for it to be a bit scratchy..all of them are like that more or less..it's something you have to live with, like the presence pots of marshall. That is due to design of the carcass which leaves too much gap and dust enters too easily in the traces. Surely you can clean it , but after 2 or 3 weeks it starts back again. I dunno if there are some tricks to mitigate that.
I have tried too to replace it with aftermarket pot (200K), no scratch, but in noway it sounds the same anymore ..sounds weakier, just like you said. Poor us vintage nuts!
Proud to be loud!
