Metropoulos 2203 replica, with a few tweaks
Re: Metropoulos 2203 replica, with a few tweaks
hi george
Do you suggest to try 56k/250pico or 56K/470 pico tone stack?
so no cap on 10K; 4,7K on cathode increase gain significantly (imho of course); maybe a 8,2K or 6,8K.
Can't you tell more about the tone stack?
thank you
hot
thank you
hot
LIFE IS TOO SHORT FOR A BAD TONE!!
- syscokid
The tone stack resistor looks like it's still a 33k. Could a smaller cap, like a 330 or 250pf increase mids?
The cathode resistor looks like a 4.2K ...too hard to tell...
"When I'm on stage and first plug in, and I feel a rush of air in my balls... That's when I know my guitar is sounding good!" -Leslie West
don't know what thinking.
george told that only cathode and tone stack tweaks were made.
Hope he wants to tell more about that tweaked 2203.
hot
hot
- VelvetGeorge
- Site Owner
Sorry I didn't document that one better. It is almost certainly a 250p or 330p in the tone stack. 4.7k cathode. I put a small cap across the plate resistors to stabilize things, not larger than a 10p or 22p.
- syscokid
Thanks for dropping some beans, George. I must have stared and enhanced that picture for about an hour, and didn't even notice the cap between the plate resistors...VelvetGeorge wrote:Sorry I didn't document that one better. It is almost certainly a 250p or 330p in the tone stack. 4.7k cathode. I put a small cap across the plate resistors to stabilize things, not larger than a 10p or 22p.
Increasing the treble cap to, say, 1000pf or higher will give a mid boost and apparent increase in gain. I've done it to my plexi and it sounds great with a Strat. Good increase in sustain.
what do you mean with "trebble cap"? the 470 p across voltage divider (470K)? or the 470pico across the 470K between V1A and V1B?SteadyEddie wrote:Increasing the treble cap to, say, 1000pf or higher will give a mid boost and apparent increase in gain. I've done it to my plexi and it sounds great with a Strat. Good increase in sustain.
summarizing the tweaks on george's amp:
V1 cathode res. = 4K7
cap between plates (not across but between plates res.) = 10 p - 22 p. (i think 22 p.)
slope res 47K or 56K
tone stack cap = 250 p - 330 p.
ANY HELP WELCOME
Need a volunteer with a ptb board to try this tweaks. (too much difficult on a pcb )
hot
p.s.
thank you George, your help is always appreciated
- VelvetGeorge
- Site Owner
Tone stack resistor should be 33k. And the cap is either 250 or 330.
I may have tried 2.7k cathode value, but settled at 4.7k.
The tone stack treble cap. Raise it to 1000pf and you get thicker upper mids and more sustain
hotguit wrote:what do you mean with "trebble cap"? the 470 p across voltage divider (470K)? or the 470pico across the 470K between V1A and V1B?SteadyEddie wrote:Increasing the treble cap to, say, 1000pf or higher will give a mid boost and apparent increase in gain. I've done it to my plexi and it sounds great with a Strat. Good increase in sustain.
ANY HELP WELCOME
hot
p.s.
thank youSteadyEddie wrote:The tone stack treble cap. Raise it to 1000pf and you get thicker upper mids and more sustain
ANY HELP WELCOME
hot
p.s.
i'll try it
hot
p.s.
is the tone still "focused"?
well
after george's last beans (thank you) the tweaks made shoul be:
slope res 33 K
Steady Eddie suggests a 1000 pico on tone stack (trebble)
Any help welcome
hot
slope res 33 K
Any help welcome
hot
What does the 10p or 22p across the plate resisters do exactly?
- VelvetGeorge
- Site Owner
It's there to keep things stable, prevent oscillations.
George,
Any certain voltage on those??
- syscokid
Obviously I'm not George, but to be on the safe side, I would use 1kv. There's still quite-a-bit of voltage at the plates of V1.guns4hire34 wrote:George,
