New speakers and SRV ?budubum92 wrote:Hi guys and gals.
heres a short and cute OTGM with CD playback. excuse my timing. its my first time playing this far of the song (except intro).
http://www.soundclick.com/player/single ... i&newref=1
Got tired of adjusting settings.
Pretty inefficient doing it by playing /adjusting.
Ordered a TC electronic DITTO record looper.
Then I can record a riff and just repeat it over and over while adjusting the EQ or hotmodding components
Sounds great, I like this one even better:budubum92 wrote:Hi guys and gals.
http://www.soundclick.com/bands/page_so ... D=13039036
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
thanks for the props guys.
yes they are with the new gear
budubum92 wrote:thanks for the props guys.![]()
This G12-65 sound just like mine.
Mid heavy “thump thump thump 200hz” and fizzy at the same time.
Is the SRV bypassed or do you use the low reverb plate setting with ~30-40 in output level to correct sizzle/fizz?
Pull some gain on the amp and keep the pot with bright cap low to get treble boost and I bet it’s much better.
100-250Hz eq pull ~5db might help also.
I think the other old clip is better also.
This is more distinct and not as fizzy.
gibsonclassic2001 wrote:budubum92 wrote:thanks for the props guys.![]()
I think the other old clip is better also.![]()
thanks for the advice.
EDIT again:
those 2 clips youve compared did have thesame EQ on the amp. it had reverb from SRV2000.
this SRV2000 seems to add a bit of brightness i kinda like btw
what speakers did you say you had?
budubum92 wrote:gibsonclassic2001 wrote:budubum92 wrote:thanks for the props guys.![]()
EDIT again:
I got all celestions.
Rigged in my rehearsal space.
I like g12m-70 best 6550
G12-100 and 80s are good to with el34
G12-75 and g12-65 are good with extreme settings.
The g12m 25w and g12h 30 works good if you can control fizz.
The SRV built in EQ cure most issues
yes the SRV does have a powerful EQ but it only affects the wet signal. any direct signal mix or dry or bypassed it wont affect them.
this SRv2000 just adds brighness no matter what. still sounds thesame almost.
- herbvis
Hey everyone. It took a while but I finally completed my 3 channel mod. It took a lot of experimenting and frustration. I ended up tossing the relay kit that I was using and went with another company. Now my amp Is a 3 channel amazing monster!!! Here is a quick video from a webcam. Just hit record and played. The sound quality is not great and some weird modulation sound and volume drops/rises occurs occasionally. Its the recording device used, not the amp. The only effect is a little reverb from my earthquaker devices dispatch master(my favorite pedal). My living room is a bit of a mess as well. Dont tell mom please.
I must say I am very happy with the results. Ill get more into the build/mod at another time
From 0 to 1:45 is "1959 mode. 1:45 to 2:45 is 2203 mode. The rest is #36 mode. I eq it at the end for some scooped metal!!! lol.
https://www.youtube.com/watch?v=P3Oo8lu ... e=youtu.be
so, it's been a while (3-4) years. some of you realy 'nail' it. yep, a well hidden asymetrical plus simetrical clipping stages. compression in the first place. don't forget to reveal photos of 'ratt' #42 and look an output stage. there are some well hidden SS components
(MOS & DI). special order tubes are essential...#36 didn't have a 4 input tubes, just + one clipping stage and more SS devices. all that telling you, there is no universal schematics (year of production, voltages, etc, etc) so no bother people who figured out the logic. they are experiment with values, also..so long with hope that this thread had to be closed for good. i'm seek when look how you make a fool of most members. everything is written here.
bye
JIG, dipl. el. ing.
bye
JIG, dipl. el. ing.
another sir# https://twitter.com/ijancec/status/5691 ... 96/photo/1
profile header sir#42 (part).
so, that would be it
enjoy !!
enjoy !!
- CoffeeTones
Explain further. Your broken English is is somewhat confusing. I will agree that it does not take 4 preamp tubes to get this sound.
*Do you mean to say that most people in this thread have been fooled?
*#36 had experimental SS circuitry? No one involved in this thread is using aftermarket, SS components to get the AFD sound.
*Someone was hoping this thread would be closed? Why?
If you are saying these things, you need to back them up with unquestionable and provable information or you will have been the one most in doubt person, that has ever joined this thread.
If that is not what you are saying, please be more precise in your postings.
- CoffeeTones
This doesn't prove much.ijancec wrote:another sir# https://twitter.com/ijancec/status/5691 ... 96/photo/1
enjoy !!
- herbvis
Im pretty sure that we all know that the guitar tracks on AFD were recorded with a peavey rage and a boss metal zone.
Oh no, now you've spilled the beansherbvis wrote:Im pretty sure that we all know that the guitar tracks on AFD were recorded with a peavey rage and a boss metal zone.
