CoffeeTones
Post by CoffeeTones » Sun Mar 22, 2015 3:00 am
BRMSlash wrote:I decided to look at my shielded wires and got rid of most of them. I also got rid of the 33k second stage grid stopper. I think the tone has improved slightly and the punch increased. Here's another clip but recorded at 24bit, which to my ears sounds more natural.
http://sclk.co/s7sdk7
Sounds fine man. I ended up with no shielded wire, except from the input jack. Never kept any plate snubbers. I sometimes use a 10k grid stopper or none. I heard a difference using around 47k stopper on stage 2. Which power and preamp tubes did you use in that clip?
BRMSlash
Post by BRMSlash » Sun Mar 22, 2015 5:50 am
Cheers. Originally I put in the 2nd stage 33k to provide a little more control to the top end, but since I stabilised the gain and treble with a resistor in line with the 2nd and 3rd stage cathode bypass caps and a large treble bleed cap on 2nd and 3rd stages, the 33k becomes a bit redundant. I was thinking of putting a 10k instead of the 33k, but I tried without one first and the amp seemed fine.
Preamp tubes were NOS Chinese Military 6N4's. However, the reissue Mullards sound extremely close as well.
Output tubes were a pair of reissue Mullard EL34's fed via a 120k equivalent PPIMV, set on max.
bennyx
Post by bennyx » Mon Mar 23, 2015 2:05 am
Unique my amp don't have lost sparkle and don't have too mid bass....probably is setting and recording the problem....i have make another sample with other setting and i have change a phone mic position
Prowler
Post by Prowler » Wed Mar 25, 2015 1:30 am
So you guys say that 6N4's are the perfect pre-amp tubes for the #36 mod? Tube Amp Doctor sells these tubes and I might order a few if you guys recommend trying them in my #36.
http://www.tubeampdoctor.com/en/shop_Ot ... etter_3138
bennyx
Post by bennyx » Thu Mar 26, 2015 3:47 am
this is the last clip
https://www.facebook.com/video.php?v=10 ... nref=story
after this clip I realized that with this scheme created a strange treble resonance.....so i have added a 470pf on second stage anode......now is better....same sound without resonance
for coffetone, i have 2 LCR NOS and 4 tad-ars filter caps.....all are in perfect condition
for Prowler, yes i have buy TAD china nos.....
for Unique: i don't have change schematic....is the same amp....i have simply changed preamp tubes....probably the phone mic don't have recorded the sparkle.......
CoffeeTones
Post by CoffeeTones » Thu Mar 26, 2015 10:56 am
bennyx wrote:for coffetone, i have 2 LCR NOS and 4 tad-ars filter caps.....all are in perfect condition
That's cool Benny. Did you test the caps with an ESR meter?
bennyx
Post by bennyx » Thu Mar 26, 2015 11:48 am
yes.....all works perfectly....i don't have caps failed.....you hear the strange resonance on treble....i have cut this problem with a 470pf filter on 100k second stage
CoffeeTones
Post by CoffeeTones » Thu Mar 26, 2015 12:12 pm
Cool man, good you figured it out :toast:
Unique
Post by Unique » Thu Mar 26, 2015 8:57 pm
bennyx wrote:this is the last clip
This sounds better, IMHO. The mids are more pronounced with the right character, and it doesn't seem to be as low-mid heavy as before. If your recording through a phone mic, then yeah, that's more than likely not going to give a good example of what the amp actually sounds like. Not to mention, where you place your phone, just like a mic, during your recording will have a great impact of the final sound. The closer to the center of the cone, facing it, the brighter the sound. Pointing away, or off center, will dull the sound and add some warmth. But much better.
Prowler
Post by Prowler » Tue Mar 31, 2015 8:37 am
Are these the right NOS 6N4 tubes for my #36?
https://www.dropbox.com/s/8qboxg6jmv0nc ... 4.JPG?dl=0
Some guy is selling four of these for 35€.
BRMSlash
Post by BRMSlash » Wed Apr 01, 2015 7:00 am
I don't think they're the right ones. The getter only has one lead in that photo. The ones on the tube amp doctor page look like the ones I've got, with two leads going to the square getter. I got mine from ebay at http://stores.ebay.com.au/xulingmrs.
Prowler
Post by Prowler » Wed Apr 01, 2015 9:29 pm
BRMSlash wrote:I don't think they're the right ones. The getter only has one lead in that photo. The ones on the tube amp doctor page look like the ones I've got, with two leads going to the square getter. I got mine from ebay at http://stores.ebay.com.au/xulingmrs.
Thanks for clearing that those were wrong tubes! I just ordered four 6n4's from TAD. I am expecting them to arrive in a week or so.
bennyx
Post by bennyx » Thu Apr 02, 2015 5:13 am
other clip
i have re add 220pf on first stage, 470pf on mixer and 100pf on gain....i had some bad welding...now is better
CoffeeTones
Post by CoffeeTones » Thu Apr 02, 2015 9:42 am
That sounds right. Are you still using shield on stage 1 and 2? What are your settings?
bennyx
Post by bennyx » Thu Apr 02, 2015 10:26 am
yes shield trick on first and second stage....setting pres 5 bass 6 mid 4 treb 5,5 preamp master 10 gain 7-8 volume 1-1,5
it's totally a 34 with boost.... :D sound like a 34 with master crancked :D
simply have just a little different mids cause have a little bright cap......
