Hey guys,
I was trying to find some old posts on this, but most seem to have all the pictures removed etc. I want to rewire the power cable so the live wire is between the fuse and the power switch instead of the neutral wire for safety's sake. I did a mock diagram, I just want to make sure I'm not missing anything?
This is the old way in the instructions
This is the proposed change. I changed the wire color for clarity.
Swapping Neutral/Live on the Fuse
- VelvetGeorge
- Site Owner
Re: Swapping Neutral/Live on the Fuse
This is correct, thanks for posting!
Even better would be using a DP/ST power switch to switch both HOT and NEUTRAL.
- Supporting Advertiser
If you want to use a use a DP switch for that purpose, the last switch in the Toggle Switch section here would work, and have the same look as the SPST used for the HT:
http://valvestorm.com/Products/Switches
See post below.
I redid my diagram. Does this display the pole layouts correctly with a DP/ST switch?VelvetGeorge wrote:This is correct, thanks for posting!
