Latest 2204ish build
This is a terminal strip build I finished last weekend. Came out really well. I will post a clip this weekend....
This one shows the .1 Sangamo's that I replaced with .039 mustards:
The amp sounds awesome...
It is a Lo-Vo 400B+ on the plates and can take 6550's or EL34's
Amps: diy SLO, Splawn QR, YBA-1
Cabs: Scumback, Rockit, Deizel
Speakers: Scumback M75, Cel. V30, wgs hm75
Guitars: Suhr, B.C. Rich
Re: Latest 2204ish build
Nice work Carl! What are you using for the red solder joint paint?
That is awesome!
Looks great! I was wondering if you stick to the standard values 470pf/470k on the input?
Yes sir, stock....danman wrote:Looks great! I was wondering if you stick to the standard values 470pf/470k on the input?
coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
http://www.vetco.net/catalog/product_in ... AmZo8P8HAQ
Nice. Sounds great.
- herbvis
I know that place. Been there a few timesfusionbear wrote:coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
Thanks Carl, I might order some. Clip sounds great!fusionbear wrote:coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
- GilmourD
Saw your thread about this amp over at TGP. Sweet Jeebus it sounds nice!
