- reychapa
Awesome, Nigeldukeamps wrote: ↑Mon Feb 05, 2024 8:18 amThe real 39 mod, AFD mix,
https://soundclick.com/share.cfm?id=14724942
reychapa wrote: ↑Fri Feb 09, 2024 7:57 amAwesome, Nigeldukeamps wrote: ↑Mon Feb 05, 2024 8:18 amThe real 39 mod, AFD mix,
TC Stage 1, Apparently this was the amp on AFD and not 36.
https://youtu.be/z9BLdBM7ru4?si=3Hei55nDc-s-EnS5
https://youtu.be/rnfx4NFbNsM?si=jrf7NX6kw7NikeoL
Enjoy
Enjoy
- CoffeeTones
Seems to be the one with the "Fender" type qualities in the tone.
Its all rock and roll babyCoffeeTones wrote: ↑Mon Mar 11, 2024 12:25 pmSeems to be the one with the "Fender" type qualities in the tone.
- sonoman1979
Hi guys, I hope you're doing well. These are raw recording just added reverb. What do you think?
This is with my oversize cab 1x12 with modern creamback
https://www.dropbox.com/scl/fi/e8u4w3yy ... 64hcg&dl=0
And in this one I used an IR (2x12 cab with modern creamback)
https://www.dropbox.com/scl/fi/1ogew1n2 ... lw1q2&dl=0
Do you know how much a cabinet can be improved by changing the baffle board? Some guy build it for me here in Peru while ago and I think he used composite wood and from what I have read it is not the most appropriate here.
Thanks!
Thanks!
- reychapa
What is the first stage like? For me it was always a classic plexi circuit with a boost with the same values as the first stagedukeamps wrote: ↑Mon Mar 11, 2024 9:40 amTC Stage 1, Apparently this was the amp on AFD and not 36.
Enjoy
Stage1 was the first mod Tim Caswell done at SIR, then came 39,36,34reychapa wrote: ↑Wed Mar 13, 2024 5:51 pmWhat is the first stage like? For me it was always a classic plexi circuit with a boost with the same values as the first stagedukeamps wrote: ↑Mon Mar 11, 2024 9:40 amTC Stage 1, Apparently this was the amp on AFD and not 36.
Enjoy
- CoffeeTones
Very nice!
