John Suhr Provided Details Regarding the SL68 (JMP SL clone)
- Tone Slinger
Re: John Suhr Provided Details Regarding the SL68 (JMP SL cl
I think your right, both Michael (JMP amp clip above) and Suhr are on the 47k/8 ohm tap. I think Michaels sounds better than Suhr's Sl-68 because of his transformers. I'm thinking the Suhr is a bit too smooth and 'soft' because of the TOO low voltages it runs at, via those custom Heyboer trannies. I definately prefer Michaels clip to the Suhr's considering he is using a Lar/Mar ppimv (as Estrada obviously used in one of the Sl-68 clips as well). Suhr has that too (Lar/Mar ppimv) as we all know, but most of the SL-68 clips is attenuated (like Thorn's clps). Having said all that, I still think that the Suhr Sl-68 is one of the best 'marketed' amps out there for early Ed type tone. The 27k/16 0hm tap is to be considered. Ralle likes it. I'm under the impression that original 12xxx tops had one of these 3 NFB circuits, either 47k/8 ohm , 47k/16 ohm or 27k/16 ohm ?
- mightymike
I liked Michael's Major clips
- rgorke
stef wrote:I think that Suhr and Michael both have 47k/8ohm. However, using the PPIMV (Michael and Estrada) affects the NFB (decreases it) and the amp sounds more distorted (due to lower NFB) and brighter and looser. My amp sounded slightly hotter and brighter even with the PPIMV (L/M) on 10.
For the first time I'm experimenting with a 27K NFB resistor
I have 27k/16 ohm....
Clips and video's do NOT do the SL68 justice. The amp is a beast in person and i was shocked at how much the clips/vids degraded how great the 68 sounded. Another thing is the amp feels amazing while you play. very responsive and singing.Tone Slinger wrote:I think your right, both Michael (JMP amp clip above) and Suhr are on the 47k/8 ohm tap. I think Michaels sounds better than Suhr's Sl-68 because of his transformers. I'm thinking the Suhr is a bit too smooth and 'soft' because of the TOO low voltages it runs at, via those custom Heyboer trannies. I definately prefer Michaels clip to the Suhr's considering he is using a Lar/Mar ppimv (as Estrada obviously used in one of the Sl-68 clips as well). Suhr has that too (Lar/Mar ppimv) as we all know, but most of the SL-68 clips is attenuated (like Thorn's clps). Having said all that, I still think that the Suhr Sl-68 is one of the best 'marketed' amps out there for early Ed type tone. The 27k/16 0hm tap is to be considered. Ralle likes it. I'm under the impression that original 12xxx tops had one of these 3 NFB circuits, either 47k/8 ohm , 47k/16 ohm or 27k/16 ohm ?
Re: John Suhr Provided Details Regarding the SL68 (JMP SL clone)
I know I'm 7 years late on this one. I really like the info and informations about the very SL68
I have read all 10 pages of discussions and did not find anything about the missing Resistors on the filter caps (56K)… see picture provided by John Surh. Normally on a SL 68 we will find two resistors 56k on the dual caps.
Is it possible that he do not use any?
Those 56K resistors usually found on the Screen Filter Caps are NOT necessary. They are there to send voltage to ground from the B+ source. When the amp is off, they also drain the caps to ground so that they do not hold a charge. Think of them like any grid leak resistor that drains signal to ground.
Here's the chassis of the SL68
SDM drawing here showing the 56K resistors on the filter caps.
- wdelaney72
If anything, removing the 56K resistors reduces ghosting.
Their purpose was to ensure dual screen caps evened out the DC shared on the 2 halves of the cap.
I never use the 56K resistors.
Walter
Make sense
Is someone have define the 2 resistors value in series with the 2 bias pots?
I believe the one in between the pots is 8.2K... not sure and have a hard time with the one above.
here is a second picture that can help
here is the picture sorry
5,6k im between the bias pots and 33k before. I’ve had two of these, one with and one older one without the PPIMV, both were pretty good sounding.
The amps use Mallorys throughout and CDE in some key positions (Cathode of V1b and V2a, cap on Presence pot). There is also a fat cap on the cathode of V2a. Both of mine had a 470pf bright cap. Filtering is 50uF throughout. The rest is pretty much a stock plexi.
Edit: My Sl68 had the 56k resistors on the filter caps, I checked the gutshots I took before selling it . Mine also had a red fiber turret board.
The filtering on the sl68 is all 50/50 uf cans? I have not been able to find much info on what exactly the sl68 uses for filtering. Could you provide what is used?
Mains and Screens - 50uF (all 50/50 uF caps),
PI Filter Cap - 100uF (50/50 uF parallel),
Preamp - 50uF/50uF
I think these were ARS filter caps. With the fat cap you really need the added filtering to keep the bottom end somewhat together, the amp has enough gain that you won’t miss the lower filtering much. Hope that answers your question.
Preamp - 50uF/50uF
Thanks, I tried the sl68 specs in my old Marshall and used lower filtering in the pre and screens. The low end was flubby and loose. Was going to try without the fat cap but this stiffer filtering makes sense.
No problem! But I think the tone of the Suhr amp depends really on the choice of materials (like every other amp).
You should come close to the tone with the mentioned filtering, Mallory coupling caps and CDE caps in the key spots. It’s a cool spec for sure.
Jewelry Pandora
Pandora Charms
Adidas Shoes
Pandora
Pandora Jewelry 70% Off Clearance
Jordan 1 High
Adidas Running Shoes
Pandora
Wholesale Jordan Shoes
Adidas
Yeezy
Adidas Shoes Women
Adidas Canada
Adidas Official Website
Cheap Adidas Shoes
Pandora Store
Balenciaga
Pandora Charms
Asics Shoes Women
Nike Canada
Pandora Charms
Nike Canada
Adidas Shoes Men
Moncler Sale
Air Jordans 1
Nike Store
Pandora Jewelry
Pandora Charm
Pandora
Goyard Outlet
Pandora Jewelry
Ferragamo Belt
Jordan 1s
Pandora Bracelets
Moncler Outlet
Asics Shoes Outlet
Pandora Charms
Pandora Jewelry
Pandora Jewelry
NMD
Nike Canada Online
Jordan 1 Low
Pandora Charms Sale Clearance
Nike Canada
Nike Men Shoes
Adidas Canada
Balenciaga Sneakers
Asics Running Shoes Women
Mens Basketball Shoes
Nike Sneakers For Men
Pandora Charms Outlet
Pandoras
Balenciaga Shoes
Adidas Sneakers
Nike Shoes Outlet
Nike Shoes
Moncler Outlet
Salvatore Ferragamo
Moncler Jacket
Jordan Retro 1
Pandora Jewelry Official Site
Pandora Jewelry Outlet
Adidas Yeezy Canada
Pandora Jewelry
Nike Outlet Store
New Nike Shoes
Pandora Jewellery
Moncler Coat
Moncler Outlet
Wholesale Jordan
Asics Sneakers
Pandora Charms
Adidas Outlet
Nike UK
Puma Store
Pandora Bracelet
Pandora Jewelry
Salvatore Ferragamo Belt
Nike Store
Pandora Charms
Nike Canada
Pandora Ring
Asics Kayano
Jordan Retro 1
Pandora Charms
Jordan 1
Cheap Moncler
Women Nike Shoes
Wholesale Jordans
Pandora Outlet
Pandora Charms Jewelry
Jordan Ones
Nike Outlet Store
Nike Outlet Store
Nike Mens Shoes
Balenciaga Sneakers
Pandora Jewelry Charms
Yeezys
Nike Air Jordan 1 Retro
Nike Snkrs
Pandora Bracelets Clearance
Pandora Rings
Nike Shoes Canada
Air Jordan 1 High
Shoes Ferragamo
Balenciaga Triple S
Pandora Jewelry Website
Asics Shoes
Balenciaga
Pandora
Nike Canada
Pandora Charm Bracelet
Nike Air Max 720
Pandora Outlet Online
Nike Running Shoes
Pandora Outlet
Adidas Clearance
Moncler Jackets
Ferragamo
Air Jordan 1 Low
Jordan 1 Dior
Nike Sneakers For Women
Nike Shoes
Goyard Handbags
Adidas New Shoes
Outlet Asics
Pandora Bracelet
Pandora Charms
Nike Shoes Women
Moncler Factory
Yeezy Boost 350 V2
Pandora Jewelry Bracelets
Nike Shoes Women
Nike Outlet
Balenciaga Shoes
Adidas Trainers
Air Jordan 1 Retro
Pandora
Pandora Charms
Pandora Charms
Adidas Shoes
Pandora
Jordan 1 High
Pandora
Adidas
Yeezy
Adidas Shoes Women
Adidas Canada
Cheap Adidas Shoes
Pandora Store
Balenciaga
Pandora Charms
Asics Shoes Women
Nike Canada
Pandora Charms
Nike Canada
Adidas Shoes Men
Moncler Sale
Air Jordans 1
Nike Store
Pandora Jewelry
Pandora Charm
Pandora
Goyard Outlet
Pandora Jewelry
Ferragamo Belt
Jordan 1s
Pandora Bracelets
Moncler Outlet
Asics Shoes Outlet
Pandora Charms
Pandora Jewelry
Pandora Jewelry
NMD
Nike Canada Online
Jordan 1 Low
Nike Canada
Nike Men Shoes
Adidas Canada
Balenciaga Sneakers
Pandoras
Balenciaga Shoes
Adidas Sneakers
Nike Shoes Outlet
Nike Shoes
Moncler Outlet
Salvatore Ferragamo
Moncler Jacket
Jordan Retro 1
Adidas Yeezy Canada
Pandora Jewelry
Nike Outlet Store
New Nike Shoes
Pandora Jewellery
Moncler Coat
Moncler Outlet
Wholesale Jordan
Asics Sneakers
Pandora Charms
Adidas Outlet
Nike UK
Puma Store
Pandora Bracelet
Pandora Jewelry
Nike Store
Pandora Charms
Nike Canada
Pandora Ring
Asics Kayano
Jordan Retro 1
Pandora Charms
Jordan 1
Cheap Moncler
Women Nike Shoes
Wholesale Jordans
Pandora Outlet
Jordan Ones
Nike Outlet Store
Nike Outlet Store
Nike Mens Shoes
Balenciaga Sneakers
Yeezys
Nike Snkrs
Pandora Rings
Nike Shoes Canada
Air Jordan 1 High
Shoes Ferragamo
Balenciaga Triple S
Asics Shoes
Balenciaga
Pandora
Nike Canada
Nike Air Max 720
Nike Running Shoes
Pandora Outlet
Adidas Clearance
Moncler Jackets
Ferragamo
Air Jordan 1 Low
Jordan 1 Dior
Nike Shoes
Goyard Handbags
Adidas New Shoes
Outlet Asics
Pandora Bracelet
Pandora Charms
Nike Shoes Women
Moncler Factory
Yeezy Boost 350 V2
Nike Shoes Women
Nike Outlet
Balenciaga Shoes
Adidas Trainers
Air Jordan 1 Retro
Pandora
Pandora Charms
