superbass spec
Share your YouTube videos or upload your mp3's.
rockstah
Post by rockstah » Wed Sep 19, 2007 12:39 am
thanks man. i should have posted this in the evh section. i thought its interesting that this spec gets evh and such a bluesy tone.
npminard
Post by npminard » Fri Sep 21, 2007 4:00 pm
badass, sounds fuckin great
rockstah
Post by rockstah » Fri Sep 21, 2007 6:44 pm
thanks! - the reason i posted the clip is I'm running an evh spec - it does van halen nicely and yet at the same time its does this kind of tone. wondered if any of you would find this interesting. but then again the train of though in both cases is " all u need is a nice sounding plexi - dimed... well i had the volume on 8
the spec I'm running.
shared cathode. 820/250u
.0022u bright channel coupler.
560pf on the bright channel mix resistor.
820 on v2 with no bypass cap.
56k/250pf tone stack.
.022u output couplers.
NFB = 4 ohm tap
4700pf cap on the bright channel volume.
mains = 50u
screens = 16u
PI = 32u
preamp dual 32u
into a 76 Marshall straight cab loaded with the prerola clones from Ted Weber.
the amp doesn't really break up until 6 or so.
i have also notice that using the bright cap value only really sounds good if u are pushing the amp past 7 and i like what it adds.
below 7 it makes the amp sound way to bright.
note: so opinions on if " should use a bright cap and what value should have the consideration of 'where r u riding the volume?' should be thought of when making this decision.
if i never brought the volume up past 5 i would think ' that cap has got to go!" and missed what it actually can add.
Mark
Guitarjb
Post by Guitarjb » Sun May 18, 2008 12:56 pm
Mark,
Which of your clips does this thread refer to? When I click the link it goes to a listing of all your clips.
Thanks,
Joe
JamesHealey
Post by JamesHealey » Mon Aug 11, 2008 9:36 am
rockstah wrote:shared cathode - 250u/820
.0022u bright channel cap
4700pf bright cap on the bright volume
560pf mix resistor
250u/56k tone stack
.022u output caps
4ohm tap
dual 32u preamp
16u screens
50u mains
20u PI cap - i forgot to hook up both sides of the dual 20u cap. :oops: i like 32u here but still experimenting.
yeah that neck pickup is a must for some of the great strat tones. ;)
This is quite similar to the spec i've got my superbass.
1000pf bright cap on the bright volume
560pf mix resistor
47k @ 8ohm tap
Jack Hammer
Re: superbass spec
Post by Jack Hammer » Wed Sep 17, 2008 4:59 am
hi mark!
your sound is fantastic as always!
in your opinion what does the bright cap adds pushing the amp past 7?
recently I've upgraded my slp with a '69 metroamp board but i decided to remove the bright cap, to me sounds more "bluesy" with volume before 7 and making a comparison with bright cap in, to me it seems don't change the sound too much when pushing the amp all the way up, maybe for the bright cap value?
