Metropoulos 2203 replica, with a few tweaks
Replica amps built by George Metropoulos himself. Visit PlexiReplicas.com.
hotguit
Re: Metropoulos 2203 replica, with a few tweaks
Post by hotguit » Thu Aug 11, 2011 6:07 am
hi george
Do you suggest to try 56k/250pico or 56K/470 pico tone stack?
so no cap on 10K; 4,7K on cathode increase gain significantly (imho of course); maybe a 8,2K or 6,8K.
Can't you tell more about the tone stack?
thank you
hot
LIFE IS TOO SHORT FOR A BAD TONE!!
syscokid
Post by syscokid » Thu Aug 11, 2011 6:01 pm
I'm trying to have fun in figuring out what you got there...
The tone stack resistor looks like it's still a 33k. Could a smaller cap, like a 330 or 250pf increase mids?
The cathode resistor looks like a 4.2K ...too hard to tell... :what:
hotguit
Post by hotguit » Fri Aug 12, 2011 8:14 am
don't know what thinking.
george told that only cathode and tone stack tweaks were made.
Hope he wants to tell more about that tweaked 2203.
hot
Post by VelvetGeorge » Fri Aug 12, 2011 12:31 pm
Sorry I didn't document that one better. It is almost certainly a 250p or 330p in the tone stack. 4.7k cathode. I put a small cap across the plate resistors to stabilize things, not larger than a 10p or 22p.
syscokid
Post by syscokid » Fri Aug 12, 2011 1:46 pm
VelvetGeorge wrote:Sorry I didn't document that one better. It is almost certainly a 250p or 330p in the tone stack. 4.7k cathode. I put a small cap across the plate resistors to stabilize things, not larger than a 10p or 22p.
Thanks for dropping some beans, George. I must have stared and enhanced that picture for about an hour, and didn't even notice the cap between the plate resistors... :oops:
SteadyEddie
Post by SteadyEddie » Fri Aug 12, 2011 5:19 pm
Increasing the treble cap to, say, 1000pf or higher will give a mid boost and apparent increase in gain. I've done it to my plexi and it sounds great with a Strat. Good increase in sustain.
hotguit
Post by hotguit » Sat Aug 13, 2011 8:22 am
SteadyEddie wrote:Increasing the treble cap to, say, 1000pf or higher will give a mid boost and apparent increase in gain. I've done it to my plexi and it sounds great with a Strat. Good increase in sustain.
what do you mean with "trebble cap"? the 470 p across voltage divider (470K)? or the 470pico across the 470K between V1A and V1B?
summarizing the tweaks on george's amp:
V1 cathode res. = 4K7
cap between plates (not across but between plates res.) = 10 p - 22 p. (i think 22 p.)
slope res 47K or 56K
tone stack cap = 250 p - 330 p.
ANY HELP WELCOME :D
Need a volunteer with a ptb board to try this tweaks. (too much difficult on a pcb )
hot
p.s.
thank you George, your help is always appreciated
Post by VelvetGeorge » Sat Aug 13, 2011 9:11 am
Tone stack resistor should be 33k. And the cap is either 250 or 330.
I may have tried 2.7k cathode value, but settled at 4.7k.
SteadyEddie
Post by SteadyEddie » Sat Aug 13, 2011 4:20 pm
The tone stack treble cap. Raise it to 1000pf and you get thicker upper mids and more sustain
ANY HELP WELCOME :D
hot
p.s.
hotguit
Post by hotguit » Mon Aug 29, 2011 5:15 am
SteadyEddie wrote:The tone stack treble cap. Raise it to 1000pf and you get thicker upper mids and more sustain
ANY HELP WELCOME :D
hot
p.s.
thank you
i'll try it
hot
p.s.
is the tone still "focused"?
hotguit
Post by hotguit » Mon Aug 29, 2011 5:19 am
well
after george's last beans (thank you) the tweaks made shoul be:
slope res 33 K
Steady Eddie suggests a 1000 pico on tone stack (trebble)
Any help welcome
hot
guns4hire34
Post by guns4hire34 » Sat Jan 07, 2012 11:30 am
What does the 10p or 22p across the plate resisters do exactly? :what:
Post by VelvetGeorge » Sat Jan 07, 2012 1:23 pm
It's there to keep things stable, prevent oscillations.
guns4hire34
Post by guns4hire34 » Mon Jan 09, 2012 4:36 pm
George,
Any certain voltage on those??
syscokid
Post by syscokid » Wed Jan 11, 2012 9:08 am
guns4hire34 wrote:George,
Obviously I'm not George, but to be on the safe side, I would use 1kv. There's still quite-a-bit of voltage at the plates of V1.
