nopvan339 wrote:If the bus wire is not soldered to the back of the pots with the Star/Larry grounding system, does the back of the treble and bass pot need anything done to them?
Help Implementing Star/Larry Grounding scheme
Re: Help Implementing Star/Larry Grounding scheme
A ground wire is coming off the back of the PI and is being grounded at point #3. Does that wire come off the negative terminal on the PI? Just want to make sure.wildebassman wrote:Hi mate!
"but the point is to have the loops spread out, and be as close to a line in their positioning as possible."
Cheers,
Dennis.
Got this project geared up again! Thanks for the help.
Jeff
- Xplorer
Hi !
i'm about to build two JTM45/100 and another superlead69.
about the JTM45/100, i'm still a bit uncomfortable in my understanding of the larry's grounding. I'd be affraid to do some mistakes. Did anybody create a layout, applied to this specific amp ?
i'm thinking of doing this, based on Billy batz's layout, so i'd just have to make sure it's ok, and then follow the design while building it.
thanks for this topic.
HI
I'm going to rewire my jmp '78 2204, which is very noisy, according to Larry's grounding scheme.
But I'm a bit confused; must not the sub stars points be linked togheter by a ground bus which IS ISOLATED by chassis and goes to ground in ONE POINT ONLY (at input jack)??? (SEE ATTACHEMENT)
In the pics of jtm 45 ground scheme each cap goes to ground in its own point; is it right? in it an alternative way of doing the grounding or what?
Who can explain me?
Thank you so much
hot
Who can explain me?
Thank you so much
hot
- groundscheme resized.jpg (51.04 KiB) Viewed 16052 times
LIFE IS TOO SHORT FOR A BAD TONE!!
Larry's grounding is not a centralised common earth rail
Each section has its own dedicated earth to the chassis:
Preamp
PI
Screens
Mains
Input etc
Essential that the input ground is dedicated to chassis, nothing else
also the heater centre tap is tied to the guitar input jack ground.
Both those things make the biggest change in my testing.
Preamp
PI
Screens
Mains
Input etc
Thank you neikeel very very helpful reply
Thank you
hot
Thank you
hot
Hi nobody has a scheme i can apply to a jmp 2204?
thank you
hot
thank you
hot
I'm FINALLY getting started on assembling my JTM45, and I just have a few things that I want to clarify before I start cutting wires and drilling holes.
In the picture way back on page one of this thread, I can see that the new ground wires are added, and the old ones aren't removed, but the input grounds are a bit confusing. I assume, that the "stock" ground wires go to the new #1 ground point, but the picture seems to show the grounds coming off the tip (rear terminal) of the jacks.
Another thing that I'm not sure about, is how to ground the bottom of the cap on the back of the presence pot. Should it "V" back to terminal one on the pot, or to one of the new grounding points? (I would guess it would be #3.)
Aside from those two things, I think it should be reasonably smooth sailing... at least til the smoke starts rolling out of it.
Hi guys, I'm almost done with my 1987... I just found out about the Larry grounding, and it's too late to drill holes :/ Can I use the transformers screws and the board screws for the ground lugs? Will there be interferences? Another thing: will the paint on the chassis create problems with grounding?
Hi all,
I am looking for the most current image of Larry's original grounding scheme for the JTM45 Metro build. Can someone point me to it?
Thanks,
John
Thanks,
John
This layout shows everything
I’m looking for the most recent grounding layout, but there doesn’t seem to be any on this thread. Can someone please reupload one?
Does anyone have the PDF that explains the Star/Larry Grounding scheme???
Thank you.
Thank you.
