MR SCARY
- NY Chief
- Wiki Editor
- plexified
Re: MR SCARY
Oh , the sauce . That's a skeleton closet , I love to cook so you pick the ten thousand ways to do so and I am gonna come through . I am sending Mr. Scary a pickup that is realy the best I have ever heard to plant in this axe . It shows that anyone can do a random act of kindness , but in this instance .....I came home to some let downs and the story goes like this .. I posted the Mr scary is building guitars stuff and then , THEN , wholly ... Shannon is carving his own scary town awesomeness. I had to admit responsibility , and I love the guy from our six year bond her on the net . See , cool things can happen , its random acts of kindness . But Mr Scary was a close to my heart project and this kid is just killing it with his enthuisiasm ! He deserves the best and here he is hard pressed to play a note . I know he is a great player But here you have THE best Seymour Duncan from the factory in the coolest body and sol . I played thousands of guitars and had a pickup variant with the custom stuff and this pickup is it . So Shannon your screwed . If Nirvana is not attained you have failed . So crazy , but he is not on the lamb . The pickup is the best I have heard in thirty years . Done . Its the bounty the booty deserves . ! You go carve that thing . Plus I have six years into knowing how cool Shannon is . He deserves the BEST . Here it is Bone doctor ! I got flagged with customs shipping stuff going to you so bear with me . Also , the piece has electrical tape , tense wound outside . If you wanna change that let it sit in the sun and pull it off . I was having this thing apart so many times to measure it was cool . Just be mindfull of the small wire wraps when you do so . Remember its a pickup that is the best of sy three hundred standard USA models and kept on a bench and stolen by me when I used it for over 25 years . he he . Hot for ...
- plexified
Re: MR SCARY
Set up an axe . Shannon you mentioned you have no axess point to adjust the truss rod . Ok , No problem . Here you want to use the right strings and just jack the neck off . If you have a neck clamp . Its not a big deal , your just untenshioning the screws in the neck . Pull it off if you want , but in doing so you relieve tension and reload the right way when adjustments go well . I would fret the first fret and the last and measure three centimeters at the twelfth fret . Or more if you like a big drama sound . I would use metal inserts in the neck with machine screws personally . The mass and the benefit is killer . No shims is the goal on the neck . You want a rock solid contact . Otherwise your gonna have some bullshit work ahead of you to get it right . And that's what we want . I don.t know anymore , Im tired , have to ko . later . CDCS . Oh I forgot you all don't know me . Charleston David Cahsmere Scott II , Turn it up !
- vanhalen5150
Re: MR SCARY
- vanhalen5150
Re: MR SCARY
Neck on, tuners, jack, ESP logo( yes I know it's JFrog).
- image[1].jpg (101.5 KiB) Viewed 4613 times
- fivecoyote
Re: MR SCARY
That is awesome! Congrats. On the hard as rock Kramer thing, I still have a Kramer Pacer I bought new back in the day, whatever finish is on it I've never seen -- it's like hard plastic. Rings like a dang bell.
At it awhile, still learnin'
- plexified
Re: MR SCARY
Yep Five Cayote , you got one , and to this crazy lad that's carving and carving . You got this one bro . I have to get this pickup into a customs thing . I was unaware of that . I put it in the smallest thing with a screen around it to be safe a faraday screen . Wow you kicked this thing way out of the park . DO we know this guy 5 cayo ? time for you to investigate . I know you like this stuff and your legacy is gonna be article soon . Or a Legacy with a write up you hiding your stuff and all . Let her rip and THEN you can all mesmorize at my new design . Its the greatest . The Greatest . Wanna talk with me ? Rock with me ? Its over . I have the BEST design . OVER . .......... I will stop now .
- vanhalen5150
Re: MR SCARY
Stuck in the screaming demon for a test drive. Nice low action.
- DSC02322.jpg (210.72 KiB) Viewed 4546 times
- DSC02307.jpg (266.34 KiB) Viewed 4546 times
- DSC02306.jpg (220.83 KiB) Viewed 4546 times
- vanhalen5150
Re: MR SCARY
- DSC02308.jpg (187.25 KiB) Viewed 4540 times
- DSC02316.JPG (229.97 KiB) Viewed 4546 times
- DSC02317.jpg (237.73 KiB) Viewed 4546 times
- JimiJames
Re: MR SCARY
Awesome !vanhalen5150 wrote:Stuck in the screaming demon for a test drive. Nice low action.
If that original DiMarzio doesn't cut it on that particular build you can try these. It has a skull on it too !
http://georgelynch.com/wordpress/introd ... y-pickups/
...lookin' good, Brother !
- vanhalen5150
Re: MR SCARY
Those PU's are a higher output than the Screaming D. It's 10k but doesn't seem to have much bottom end.JimiJames wrote:Awesome !vanhalen5150 wrote:Stuck in the screaming demon for a test drive. Nice low action.
- Strat78
Re: MR SCARY
Job well done, because all I see is osteoarthritis. I'll bet that guitar screams (with pain)!
- mikefont
Re: MR SCARY
DAMN...KILLER job on that guitar bro!
Currently in tonal HEAVEN with my Bray 4550 Deluxe!
