bmwfreq
Post by bmwfreq » Sun Jan 25, 2015 7:25 pm
Prowler wrote:Did you mod your amp, or did you have it done?
I modded it myself[/quote]
Did you use the #34 mod specs that Santiago gave to the forum? (I'd post the schematic I'm talking about, but somethings wrong with the site and it hasn't allowed anyone to attach files to their posts) :palm:
Prowler
Post by Prowler » Sun Jan 25, 2015 9:37 pm
It is the layout that has 2200 pF // 470 K peaker combo on the pre-amp gain pot. Coffeetones suggested some changes and I tried many different component values which sounded the best.
bmwfreq
Post by bmwfreq » Sun Jan 25, 2015 11:42 pm
HOLD THE PRESS!!!!!! :peace:
I think I have discovered the key to the highly sought after 'wah' effect thats been missing from the #34 mod all this time...and it has nothing to do with the "Hot-shield"; or the tubes'; or the volume level'; or the speakers'; or the way you strum the strings... well, maybe a little to do with how you strum the strings.
It does have to do with a component that is added to the mod. I think Santiago just overlooked it, and Frank has been holding out on us. :scratch:
Who has a modded JCM 800 with the #34 mod, and that wants to give this a try?! :shrug: I don't want to put this out there until someone else tries this first.
gibsonclassic2001
Post by gibsonclassic2001 » Mon Jan 26, 2015 1:14 am
bmwfreq wrote:HOLD THE PRESS!!!!!! :peace:
Sure..PM me and ill give it a try.
gibsonclassic2001
Post by gibsonclassic2001 » Mon Jan 26, 2015 3:28 am
budubum92 wrote:Hi,
Here`s a late night clip with the SRV-2000.
http://www.soundclick.com/player/single ... i&newref=1
Budubum
Use the SRV Fizz control explained a few hundred pages ago 
The SRV PA reverb add fizz if it’s not controlled by the built in function.
Also make sure you have done factory reset (hold a couple of switches at power up or something like that) and that level on rear panel is at the mark.
The fizz control is sensitive so just pull a little and see what happens.
To much and it kills the chime/jangly tone
budubum92
Post by budubum92 » Mon Jan 26, 2015 5:52 am
you talking about the lower resistance on V1a plate?
budubum92
Post by budubum92 » Mon Jan 26, 2015 5:56 am
gibsonclassic2001 wrote:
budubum92 wrote:Hi,
Budubum
yes its write and reverb/nonLinear botton held while startup thats factory reset.
whats the fizz control`?
the balance mix is i believe just under 0900 mark on the knob. i havent check it back there coz i have this unit above my pc table and thats teh only safe place noone`s gonna bump into it.
damn it,im so carefull with this thing. its been on its like new condition since 85 and just bought it from 2nd owner and just been studio used. battery is also original. :champ:
budubum92
Post by budubum92 » Mon Jan 26, 2015 6:03 am
a quick search reveals the fizz control is the shift 6 or output of the reverb. its just basically controls how much reverb that patch is going to be mixed in.
i need a patch or setting that can put my dry signal "infront" of teh mix while the wet signal "at the background".
i believe that is how AFD tone reverb was achieved so as to preserve the original tone and just creates spaciousness without muddiing.
SCOM is different but i still do hear like 10% dry signal in the mix.
gibsonclassic2001
Post by gibsonclassic2001 » Mon Jan 26, 2015 10:30 am
budubum92 wrote:a quick search reveals the fizz control is the shift 6 or output of the reverb. its just basically controls how much reverb that patch is going to be mixed in.
That damn search function is down. :(
Here are my old notes
Check setting on rear panel. Set on "dot/marking"
Then control fizz with output control on the switch to the right of the display.
"Most used due to the fact that blend is on rear panel and not something you use in a rack mounting.
So output control helps me with sizzle control."
Btw did you try the secret Delay function hidden in the SRV?
Hold 3 buttons and hit power and it will power up as delay :)
bmwfreq
Post by bmwfreq » Mon Jan 26, 2015 11:07 am
I really think the whole spirit of this forum has been lost. Really? Someone states that may have made a breakthrough regarding the #34 mod; actually found something that's been alluding everyone here for more than 635 pages, and all you can talk about is "reverb", and "look what I can play"?
I'm going to focus on a new forum that I have started, which will talk about all things 'pertinent' to the actual #34 mod.
Good luck everyone, and keep those recordings coming!
1984 2203 JCM 800
(#34 mod)
1960AV 4x12
2x12 25 watt Greenbacks
2x12 Vintage 30's
| O O |
| O O |
gibsonclassic2001
Post by gibsonclassic2001 » Mon Jan 26, 2015 1:52 pm
bmwfreq wrote:I really think the whole spirit of this forum has been lost. Really? Someone states that may have made a breakthrough regarding the #34 mod; actually found something that's been alluding everyone here for more than 635 pages, and all you can talk about is "reverb", and "look what I can play"?
I pm'd you about it.
But you didnt answer.
I guess most user thought you wanted to keep it off the board.
And in the case of afd the srv contain such impact on the final tone .
bmwfreq
Post by bmwfreq » Mon Jan 26, 2015 2:23 pm
I just checked my PM in box, and for some reason or another I don't have a PM from you...
I only have one person that has PM'd me since June of last year.
herbvis
Post by herbvis » Mon Jan 26, 2015 2:26 pm
So whats this #34 discovery?
gibsonclassic2001
Post by gibsonclassic2001 » Mon Jan 26, 2015 2:40 pm
Pm you again.
budubum92
Post by budubum92 » Sat Jan 31, 2015 6:56 am
