I have the PCB out, and I'm installing the 69 brown board in my 73 JMP SL. I was able to lay everything out real clean and straight. I'm trying to use as much of the original wiring as possible to keep all the red dye, but there's a couple that won't reach
I need some soldering assistance::
I really want to do a nice job.
I'm in the middle of open amp surgery and I feel like I need to stop and practice soldering. I've ssen the pics on George's CD and mine just isn't up to snuff. How are you suppossed to hold the tip? Are you supposed to heat up the outside of the turret, while feeding the solder inside? Or do tip and solder both go in the turret? I can' seem to get enough heat with the first method.
Which Light:
I cracked my Square Red light and presence knob taking the chassis out of the case. Is that light a 6.3 Bulb? At George's store there's a $10 and a $4 light. With my luck it's probably the $10 one
I bet it's easier to wire build an entire amp kit, than to swap out boards while using the same wiring. This is my first time.
