schneidas
Post by schneidas » Fri Mar 09, 2018 7:25 am
Hi guys,
would someone be kind enough and point me to an authentic #36 and and another #34 layout so I can build these myself?
The old layouts seem to have been removed.
I'd really appreciate it, if someone could post these again.
Thank you in advance :)
CoffeeTones
Post by CoffeeTones » Sat Mar 10, 2018 11:30 am
schneidas
Post by schneidas » Mon Mar 12, 2018 4:07 am
Thank you very much, kind sir!
Much appreciated! :)
schneidas
Post by schneidas » Tue Mar 13, 2018 7:16 am
bmwfreq
Post by bmwfreq » Tue Mar 20, 2018 2:56 pm
Has anyone here successfully used a "THD Hotplate" with either the #34 or the #36 mod?? If so, can I get some input as to functionality and tone coloration? Did anyone experience any adverse affects using one of these?
I've heard stories about people burning up diodes using this attenuater.
Any information would be greatly appreciated.
Thanks in advance.
1984 2203 JCM 800
(#34 mod)
1960AV 4x12
2x12 25 watt Greenbacks
2x12 Vintage 30's
| O O |
| O O |
wdelaney72
Post by wdelaney72 » Tue Mar 27, 2018 11:36 am
I've had a THD Hot Plate for years and never fried diodes.
I cannot be specific to #34 or #36 buy of course there will be tone compromises using ANY Attenuator. In terms of playing out live and being functional, the tone concessions are manageable given the benefit.
I have resorted to using PPIMV for all my builds. I think it it's more true to the tone than the HotPlate.
Walter
bmwfreq
Post by bmwfreq » Sun Apr 15, 2018 4:53 am
I'd have to agree with ya here. I've been using a PPIMV for about 6 years now, and it's the single most practical mod anyone could do to their amp. Not only does it allow you to play at bedroom levels with Master Volume cranked to 8, it greatly increases the life of the power tubes.
Attenuators can over work your amp, leading to burned rectifier diodes, buy it can also red plate your power tubes which is never a good thing. You can't get an accurate Slash #34 tone without a PPIMV or an attenuator.
bmwfreq
1984 2203 JCM 800
(#34 mod)
1960AV 4x12
2x12 Vintage 30's
| O O |
| O O |
bmwfreq
Post by bmwfreq » Wed Apr 18, 2018 3:24 pm
Based on the collective knowledge base here in this forum, I thought where better to pose this question...
Does anyone know what 6550s available on the market today, come the closest to the 6550s that Slash uses in the #34??
I've been using the Tung Sol 6550's with great results, but if there's a tube out there that'll get me even closer to the tone of the #34, well....why not???
Thanks in advance to all that reply.
1984 2203 JCM 800
(#34 mod)
1960AV 4x12
2x12 Vintage 30's
| O O |
| O O |
snakepit86
Post by snakepit86 » Thu Apr 19, 2018 12:48 pm
I 've tried JJs and they are cool, also i've got some GTs back in the day and there werent better than the jjs
bmwfreq
Post by bmwfreq » Thu Apr 19, 2018 1:36 pm
Thanks for the reply.
I have some JJ 6550s, but I'm not impressed with em. I would definitely have to say that the Tung Sol 6550s sound way better than the JJs.
What I'm really looking for is a power tube that will closely resemble (sonically) the Chinese coke bottle tubes that we see in the #34. Having only experienced the Tung Sols and JJs, I'm pretty much dependent on other peoples experiences.
1984 2203 JCM 800
(#34 mod)
1960AV 4x12
2x12 Vintage 30's
| O O |
| O O |
captainvee
Post by captainvee » Thu May 03, 2018 2:28 pm
HI,
I've done #36 mod on my 2013 JCM800 2203X and it sounds really good, but I have a problem (I think I had this problem before modding the amp too, but it wasn't this bad), when I connect my pedals in front of the amp they make the amp sound really thin, they make my humbuckers sound like single coils.
I used my MXR EQ, BOSS RC-3 and TC Electronic HoF 2 and they all make the amp sound thin. Is this normal?
Also when I try to measure the 1Meg ohm input grid leak resistor through my guitar cable it measures 1Meg ohm, but when I turn the amp on (just the power switch) it drops to 27K ohm. Is this normal on JCM800? because when measure this resistor on my Laney CUB12R (which is a clone of JCM800) it measures 1Meg ohm even when the amp is on. Could this be related to problems with pedals too?
Thanks.
BRMSlash
Post by BRMSlash » Fri May 04, 2018 1:11 am
It's official! Appetite for Destruction Remastered & Expanded! :D
https://lnk.to/AppetiteForDestructionWe/gnrstore
https://www.gunsnroses.com/
snakepit86
Post by snakepit86 » Tue May 08, 2018 3:07 pm
You 've just made my day
herbvis
Post by herbvis » Tue May 08, 2018 5:06 pm
for the low price of 1000 dollars!
Unique
Post by Unique » Wed May 09, 2018 12:03 pm
Or you can just get the CD by itself with the added tracks for about $14. That's not bad.
