I wanted to make lower watt version of Electric Amp MV120 (schematics). I decided to use two 6v6 tubes and to use power supply from Plexi 6v6 schematic.
I know most of the sound comes from the preamp.
This is my first time designing an amp and I have some questions. I have built one amp before though (AX84 HiO). I may be asking too much but could somebody check if it looks safe to build?
I want this amp mostly for the very heavy distortion/fuzz sound you can get. But I changed the tone stack for experiment and FAC caps (they looked like wrong compared to orange or matamp amps). I also added the unused V1B in parallel with V1A.
Does the transformers and choke I have chosen look like they would be good for this? I get 230V from wall outlet.
Hammond 156R choke would be equivalent (I read from forums) to the NOS choke in plexi 6v6 schematic, but I chose 157R because it has 2 henries instead of 1.5. I want to play this amp with bass too so I would like to have good bass response - do I need even higher inductance in choke? Bass response is good in the OT and its easy to change some caps if needed. What about the 400 VDC max rating - too low?
Here is the schematics
