power tranny?
All about iron and copper.
rockgod212
power tranny?
Post by rockgod212 » Thu Jan 04, 2018 5:31 pm
hello all, I thought I would post this question so others would know as well. I couldn't find any info on this, so here it goes.
im in the process of returning my metro 1959 clone back to stock plexi specs and I noticed my power tranny has this yellowish waxy film on the end bells, I can only assume that it is from the tranny laminations. what could have caused this? overheated tranny perhaps? is it anything to worry about? just curious about this before I fire it up again.
"purple power rules"
danman
Re: power tranny?
Post by danman » Thu Jan 04, 2018 7:36 pm
I have seen PT's ooze black, tar looking stuff after years of operation but they still seem to perform fine. In your case, I think that the manufacturers coat the transformers in clear varnish that eventually turns yellow over time. Kinda like how older guitars yellow a bit over time. The yellowing is likely from heating that occurs during the amp's use and will not cause any problems.
rockgod212
Re: power tranny?
Post by rockgod212 » Thu Jan 04, 2018 9:10 pm
ok gotcha. good to know.
rockgod212
Re: power tranny?
Post by rockgod212 » Fri Jan 05, 2018 11:59 am
I wonder if I can run 5 preamp tubes of that metro power tranny? does it have enough juice?
Re: power tranny?
Post by neikeel » Fri Jan 05, 2018 5:30 pm
In terms of HT certainly, in terms of heaters, x5 ECC83 is 1.5A, and EL34s need the same each, so looking at 7.5A heater draw, which is probably close but I think you will get away with it.
rockgod212
Re: power tranny?
Post by rockgod212 » Fri Jan 05, 2018 6:51 pm
ok I will give it a shot then
rockgod212
Re: power tranny?
Post by rockgod212 » Fri Jan 05, 2018 7:17 pm
would it help things if I went to DC heaters, as I just bought a board for that.
Re: power tranny?
Post by neikeel » Sat Jan 06, 2018 8:34 am
Depends what mods you are doing, but most DC heaters still take their draw from the 6.3vac line at some point.
I think V1 in a high gains setting benefits from DC heaters. Never had to do it myself but I know George had to on the Metroplex.
rockgod212
Re: power tranny?
Post by rockgod212 » Sat Jan 06, 2018 5:43 pm
my original goal of using 5 pre tubes was to have both stock plexi channels, then full on 800 channel with xtra stage. I know the ways of how to do it, was just wanting to do something different switching wise. I know I can do what I want with just 4 tubes though. running 5 tubes was just a thought really.
