To this:
To this:
The last picture is the same type of tag on my 78' 1960A cabinet.
Someone told me that they started putting the plastic cab corners on the cabinets in late 72. Does that sound right? Mine doesn't have the corners, nor does it have any holes where they may have been.Scumback Speakers wrote: ↑Wed Jan 24, 2018 6:17 pmThe really small white tag is 60's, early 70/71. That bigger black and white tag is 72-77, I believe. And the silver tag is definitely late 70's, probably 77-82.
If the speakers are original to the cab, they'll be the best way to date it properly. I realize that's probably a long shot, but it would be worth a look if you really want to know.
You'll need the Txxxx # and the alpha numeric date code off the speaker frames to do this.
Good luck!
Jim
Thanks Jim. I have two 1972 G12m 75hz greenbacks that have been reconed with Mueller cones in the 80s and sound really stiff. Any suggestions for a Pulsonic type recone?Scumback Speakers wrote: ↑Thu Jan 25, 2018 11:36 amYes, late 72 sounds about right if you never had plastic corners.
