Please help me out. 1969 100w build
no0sand1s
Re: Please help me out. 1969 100w build
Post by no0sand1s » Tue May 15, 2018 4:40 pm
neikeel wrote:
Wed May 09, 2018 1:44 pm
Ok so the 100-460 is:
I REMOVED THE HT FUSE AND READ -.38VDC - 0.0VAC I NOTED BOTH GREEN WIRES FROM PT (FILAMENT PRIMARY AND BIAS) GOING TO GROUND LUG NEXT TO CAP F6
REPLIES BELOW IN CAPS:
CURRENT PHOTOS: https://www.flickr.com/gp/wedinbordeaux/58Uz78
Primary
orange is common to power switch which when on goes to the selector switch (or neutral if no voltage selector - is that black in US cords?). NO VOLTAGE SELECTOR. ORANGE GOES TO MAINS FUSE, RED TO POWER SWITCH. EUREKA MOMENT?!? The red wire to the other half of the switch goes to one end of the mains fuse, the other end of which gets feed from power cord live (US = white?). YES Other power cord wire I presume is green which is ground? WHITE=HOT, BLACK=COMMON, GREEN=GROUND
Check you have 120vac across the mains switch 6.7VAC
Secondaries
Blue/white and grey go to each half of the standby switch with the yellow centre tap to the junction of the mains cans (looks correct in pics) YES. NEW PHOTOS ADDED.
check you have 350vac across the lugs of the standby switch 177.8VAC
the feed to the cans comes to them via the red wire from the apex of the rectifier with another spur to the HT fuse which then via the fuse feeds the turret on the corner of the board. YES
check at this corner lug point (and on the fuse and red wire of mains filter cans) measure between ground and you should have about 460vdc. -.39VDC
Then follow the B+ line from that corner lug to the one where the choke feeds the screens (two yellow wires and choke wire) you will get a slight drop here - maybe 450vdc. -.39VDC
Chase along the droppers (to the lug where the 10k MO resistor hooks to the black wire and blue wire) you will get a 20-30v drop here. -.46VDC
Do these checks an post back
Post by neikeel » Wed May 16, 2018 4:05 pm
It seems at first pass that there is a problem with the wiring of your PT.
You should get 177vac on either side of the centre tap (between blue/white and yellow and between grey and yellow) so you have half your HT, pre-rectifier. You might see 177vac between ground and each stand by lug?
If not the wiring from the PT is off.
To be sure you will have to unsolder all the PT secondary wires and screw them into a terminal strip (colloquially called a chocolate block connector) just to keep the wires safe from hands and touching.
Then measure between wires, then you know it is not your wiring to the amp.
Tazin
Post by Tazin » Wed May 16, 2018 6:15 pm
6.7Vac at the mains switch (ON/OFF) is way off. Use your Multimeter to check the outlet for 120Vac (between the narrow blade slot and the ground hole). If that checks out fine then plug the amp in (but leave it off) and check between the black wire that connects to the mains (ON/OFF) switch and ground (chassis) for 120Vac.
no0sand1s
Post by no0sand1s » Sat May 19, 2018 5:53 pm
no0sand1s
a
no0sand1s
Post by no0sand1s » Sat May 19, 2018 6:24 pm
I get 125VAC between ground and the black wire to mains switch. The indicator light turns on - I get 125VAC on the red wire to the lamp, but no reading on the black wire - this leads to the mains fuse and there's no voltage showing on either terminal.
I unsoldered secondary wires and attached to terminal strip. See VAC I'm reading : https://www.flickr.com/gp/wedinbordeaux/L614UY
There are 2 green wires showing different voltages - should I be surprised there are no individual identifiers for these...
What's the next step? Call Mercury?
Tazin
Post by Tazin » Sat May 19, 2018 7:43 pm
Well, you have the correct wall voltage (apprx. 120Vac) at the mains (ON/OFF) switch...The black wire from the Indicator lamp should not have voltage since it is connected to the Mains Fuse along with the White wire (neutral) from the AC power cord. The Metroamp instructions puts the Mains Fuse inline with the Neutral wire (just like Marshall did back in the day) rather than the Hot wire (black wire). The two secondary Green wires don't require identification from one another since they are both used as Grounds in this application. You could run both the Green secondary wire back to ground again and re-check the AC voltages at the terminal block but with the numbers I see that you listed from your initial test tells me something is wrong with the PT. Perhaps neikeel has some insights or a new "plan of attack"...I'd wait for him to chime in.
Post by neikeel » Sun May 20, 2018 4:54 am
Can I just double check.
Meter set to ac volts, add probe to wires I mention (not to ground unless I say)
Your input voltage is 120v into the orange and red pair of wires only? The other wires are turned back and shrink wrapped?
Heaters
Measure between thick black and black wires should equal about 6.5vac (half that between black/green and green/black)
Bias
Measure between white and green bias wires (check for continuity first) should get around 95vac.
High Tension
Measure between grey and blue/white wires should get 350vac (and half that between these and the yellow CT).
What have you done with the brown and brown accessory wires (hopefully folded back and shrink-wrapped away?
Let us know what happens.
If you do these tests and don't get these readings the PT needs to go back to Mercury.
