1974 Marshall PT color Confirmation?
glpg80
Post by glpg80 » Sat Apr 04, 2020 12:49 pm
In the process of going through and restoring my 1974 Marshall I’ve noticed the secondary B+ wiring color code is odd.
I’ve got:
B+:
Blue (hot)
Yellow (center)
Red (hot)
Bias:
White (hot)
Green (gnd)
Heaters:
Black (hot)
Solid Green (gnd/center)
Black (hot)
The heaters have 0.05 ohms between the center tap and hot.
Nothing I have found shows blue as a B+ hot wire. Is this a stock Dagnall PT?
Re: 1974 Marshall PT color Confirmation?
Post by neikeel » Thu Apr 09, 2020 4:13 am
Can you post some images of your PT?
The heaters and bias taps sound correct but the HT sounds funky.
Yellow is a normal centre tap colour
The HT on both my 71s are Blue/Black
glpg80
Post by glpg80 » Sat Apr 11, 2020 3:56 pm
The amp is currently upside down and torn apart, no good pictures right now unfortunately.
Yeah the HT is a little suspect. When I bought the amp I didnt see any writing on the bells. The transformers look original and I was told they were original. The string wrapping was still present before the restoration began and had that rosin light coating on them so it seems original?
