Mercury Magnetics P4550JT-G2
Post by VelvetGeorge » Wed Jan 31, 2007 9:39 pm
MM P4550JT-G2. intended for JTM 45 and 50 watts.
(9.41 KiB) Downloaded 6751 times
P4550JT-G2.pdf
(17.33 KiB) Downloaded 6082 times
Post by VelvetGeorge » Wed May 09, 2007 5:44 pm
It seems that MM has changed to terminals for some of the wires on this PT.
Here are a pic and a diagram for the new version.
(76.83 KiB) Downloaded 6721 times
(82.26 KiB) Downloaded 7758 times
Re: Mercury Magnetics P4550JT-G2
Post by VelvetGeorge » Mon Sep 22, 2008 12:58 pm
With regard to our JTM 45 kit:
Select the correct color primary wire for your operating voltage.
BLACK 117V
BROWN 220V
RED 230V
YELLOW 240V
The terminal labeled "COM" will replace the orange wire indicated in the instructions.
Terminals 9,10 and 11 correlate to the green heater wires. With 10 being the center tap which gets grounded.
Terminals 12 and 13 correlate to the yellow rectifier heater wires.
Terminals 6,7 and 8 correlate to the red high voltage wires. With 7 being the CT which goes to the fuse holder and then to ground.
