Any Feedback from you Fender guys on these tubes???
Thanks!
Ken
does that mean i can drop the 5881's in my jcm 800 without re-biasing. im running the el34's at 35-39ma... where should the el-34's be biased??Seems like I run my WGB's at 34-35mA too
i guess i would have to change over from the 1k 5 watt to the 470 then?? or is the 1k better??You can go ahead and run those over 400V. Just make sure the 470 screen resistor stays in spec. And expect about half the lifespan.
