Have an amp (two 6v6, 3 12ax7, one gz34).
Here it goes:
The overheating (actualy failed) resistor is in a bleep type position, between two capacitor (multi can type) ternimals that is feeding the 6v6 screen's, that multican capacitor is fed by the rectifier itseft but there is a 100OHMS high power resistor in series between the rectifier and our multican cap, also there is an other cap (axial) that is in series with that hight power resistor receiving the rectifier DC as well.
Why is that resistor on the multican started to redhot and fail, I removed it replaced it ans the new resistor failed as well, it is pullilng to much watts there, why?
any suggestions will help cheers!!
