More honest than my attenuated ( well UA'd dan ) 100W marshall
Yeah but thats just a load+DI. As far as I know you cant use that to play through unless you go DI into the mains or a computer or mixer. I listened to those clips a while back and it seemed interesting to be able to record with but as a live tool its expensive for what would only be a load if you can even use the load indepndantly. If you just go DI with it thats great but I dont like that.Anonymous wrote:I was cruzing around this forum and someone posted a link to the Motherload Speaker emulator I heard the sound clips ... amazing to say the least. It is pricey at 869.00but if it I get results like those MP3 s
worth every penny and direct recording and backline capabilities any any volume
This may be the way to go![]()
Scott
http://www.motherloadusa.com/motherload ... x_home.asp
Thats what I want the thing for. Home playing. But I do already have the mass which has a nice clear Line Out and Im thinking of just getting that Songworks poweramp which is tiny to replace the bulky one Im using now. If I got the UA tahts $550 since Id probably want at least 2 options. I just dont thinkg I could swing that any time soon for that. I think the problem at higher volumes (this was just speculation on my part earlier but its nice to hear a confirmation) is the same problem with all SS amps when you crank them. They are all a bit flat sounding but it seems most apparent when you turn them up. They sound great down low.bluefuzzguitar wrote:Dan, Paul,
DBII uses V30's. I use them too and love them! I have V10's in both my Fender Super Reverbs and have come to appreciate the 60w rating as the ideal wattage for me. Enough to stay tight when pushed without sounding sterile.
As for the UA, I own a Super Ultimate Attenuator (glad to see you're also an UA user, Paul!). My SUA has a 300w power tranny so it can handle the full power of my Super Bass. I owned a Hotplate before the SUA and the SUA is sooooooooo much better, especially at lower volumes as Dan remarked. The interesting thing about extreme attenuation settings with the SUA is that it sounds great at home, so much so that it can cause you to be overly confident that sound will also hold up in a band setting, only to find out that it sounds like ass in a band, even if the entire band is at low volume. I'm sure Dan won't be surprised when he reads this because that's been his point all along with any attenuator. Once you get past the level where the speakers are no longer pushed in any significant way (on the SUA anywhere down from the volume at 11 o'clock), you'll get a different frequency response coming from the speakers, causing them to sound 'flatter', 'deader', less inspiring. This is particularly important for retaining the character of your amp sound in a band setting. It's a problem that can't be solved other than just turning up. I guess I should count myself lucky to have an attenuator that continues to sound transparent even at very extreme settings, at home at least.
I disagree with you, Paul, about the plexi switch. I actually love that switch and I have it on all the time, no matter what level of attenuation I'm using. I find it adds some sweet upper-mid harmonics that are lacking otherwise since the SUA sounds fairly dark without this switch. It's a good approximation of the metallic clang plexis have at full bore. Maybe you should give it another try with this in mind, Paul!
Mike
