Littlewyan
Post
by Littlewyan » Fri Sep 29, 2017 7:12 am
Use a chopstick if you have one. A valuable tool
It can be something in the house causing it. I get a lot of interference in my rehearsal space sometimes. I also had a lot of issues when I built this amp into a small Pignose chassis and could never get it to be quiet or not oscillate. There might be hope for your's though as you have a decent size chassis.
Does the buzz get worse when you plug into the low input? Are all of your grounds connected correctly? Checked them with a meter?
marshallnoise
Post
by marshallnoise » Sat Sep 30, 2017 4:21 am
I did some reading and determined I better get the guts of this amp into a different chassis. So I built a chassis today. Pics will follow at some point.
The current issue is that the OT is on the opposite side of the chassis as the PT. So I understand that long runs from the OT are not good and if they pass by the preamp, then noise will absolutely happen. I spent some time with grinders, cut off wheels and my welder and came up with a new chassis that is a bit smaller than a full size Marshall chassis. It measures in at 24" x 7" x 3". It will have plenty of room for mods down the road if I want and I am leaving it rusted up a bit with a nice patina. This amp is as much an art piece as anything else.
EDIT: The grounds check out good and the hi-input just amplifies the same noise as the low-input.
Littlewyan
Post
by Littlewyan » Sat Sep 30, 2017 4:25 am
That's pretty cool that you made your own chassis!
There are a lot of amps out there with the OT on the preamp side but I don't know how they're wired. Like I don't know if they run the wires on top of the chassis or straight in at the preamp end.
Post
by neikeel » Sat Sep 30, 2017 9:39 am
OT and PT at either end is no issue. Look at oranges and hiwatt. Just keep your secondaries to the output jacks shortish and ideally have the output tubes fairly close too.
marshallnoise
Post
by marshallnoise » Sat Sep 30, 2017 11:59 am
Yeah, the long runs are the problem. I had to use the tube socket holes that were already in the chassis. So the OT secondary AND primary leads had to run a long way. Bugera uses ribbon cable for all their connections and several daughter boards and stuff.
marshallnoise
Post
by marshallnoise » Sat Sep 30, 2017 5:57 pm
Is it bad practice to have the filter caps located directly underneath the power transformer?
Post
by neikeel » Sun Oct 01, 2017 4:19 am
marshallnoise wrote: ↑Sat Sep 30, 2017 5:57 pm
By that I presume your caps are going to be properly mounted to radial cap mounts horizontally to the side walls of your chassis (said he hopefully) and not glue gunned. In that case no problem. Other way is axial caps on a cap board, which again can sit inside under your PT.
marshallnoise
Post
by marshallnoise » Sun Oct 01, 2017 11:18 am
neikeel wrote: ↑Sun Oct 01, 2017 4:19 am
Haha message received.
Littlewyan
Post
by Littlewyan » Mon Oct 02, 2017 8:32 am
Take your time doing it. I went through exactly the same process as you. Built it into a chassis that wasn't suitable, couldn't make it quiet, moved it to a proper chassis
marshallnoise
Post
by marshallnoise » Mon Oct 02, 2017 7:10 pm
Littlewyan wrote: ↑Mon Oct 02, 2017 8:32 am
Yes, I am taking my time now. I can't believe you tried to stuff this amp in a Pignose!
Here are some pics. I have started to drill holes and killed a step bit already. Switched to a holesaw and its working better.
IMG_20170929_124119013_HDR by
Paul Abbott, on Flickr
IMG_20170929_124959386 by
IMG_20170929_131625408 by
IMG_20170929_140607948 by
IMG_20170930_135952601 by
Dimensions are 24"x7"x 3". Total coincidence the other chassis was virtually the same.
Littlewyan
Post
by Littlewyan » Tue Oct 03, 2017 3:17 am
Haha. The Pignose G40V is a very similar circuit, so I just modified it. However it sounded terrible, was noisy and with the treble above 5 it would oscillate!
For the holes you should use a hole punch. Much easier. Not that cheap but if you use them a lot then the cost isn't so bad
So you're building a rat rod amp
marshallnoise
Post
by marshallnoise » Tue Oct 03, 2017 11:28 am
Littlewyan wrote: ↑Tue Oct 03, 2017 3:17 am
Ratrod! Exactly! That's a great description.
Using a hole punch would have made much more sense but my step bits worked fine for all but the big holes.
Holes by
Holes by
Not the cleanest. But "Rat Rodding" makes the mistakes just part of the theme. LOL
Post
by neikeel » Tue Oct 03, 2017 12:55 pm
marshallnoise
Post
by marshallnoise » Wed Oct 04, 2017 2:52 pm
Ordered a few goodies for this thing. I decided to hit up ValveStorm for some hookup wire instead of using the cheap RadShack crap I was using before. I also ordered some new 9 pin sockets because the ones I have won't fit or mount up. I made the holes too big on all of them, but at least the power tube sockets fit just fine. I used #8 1/2" Teck screws to self tap them into the chassis. Worked like a charm.
I also got 12 bronzed chicken head knobs that will go with the rat-rod motif.
https://www.amazon.com/gp/product/B01F6 ... UTF8&psc=1
This whole process pretty much reeks of "do it right the first time, dummy." Or "an ounce of prevention is better than a pound of cure."
But its fun!
Littlewyan
Post
by Littlewyan » Wed Oct 04, 2017 7:59 pm
Got to learn somehow mate. Can't learn unless you cock up
. I speak from plenty of experience
Those control knobs look pretty damn cool! Do the sockets feel secure with the self tap screws?
