mission amps tweed deluxe (help)
So, I put this little devil together a little while ago, but shes been giving me quite a hard time. I'm running into some major hum/grounding problems??? With the amp turned fully up, its just screaming with hiss. Plus, when I hit the low E, the amp is producing a kind of broken sound. Not in the cool, tweed deluxe/neil young broken kind of sound, just bad.
Some alterations from the original kit would include the mercury magnetics 59 OT. Any advice would be so very greatly appreciated.
- P1030019resize7.jpg (371.58 KiB) Viewed 1837 times
- P1030017resize6.jpg (394.01 KiB) Viewed 1836 times
- P1030011resize4.jpg (387.59 KiB) Viewed 1836 times
- P1030021resize5.jpg (412.42 KiB) Viewed 1835 times
- P1030011resize4.jpg (389.45 KiB) Viewed 1836 times
- P1020996resize3.jpg (384.55 KiB) Viewed 1836 times
- P1020993resize2.jpg (423.85 KiB) Viewed 1834 times
- P1020990 resize.jpg (364.66 KiB) Viewed 1834 times
Re: mission amps tweed deluxe (help)
I wish I could offer some help but to be honest I really don't know enough about electronics to help. Maybe if you posted something besides pictures somebody here could help - schematics, what you have done so far to try and fix the problem etc..
Good luck...
Good luck...
Hi there!
I'm about to take the plunge and buy a Mission Amps 5E3 kit. Have you solved your problem and what's your feedback on the kit and the amp's tone ?! Would you recommend Mission Amps?
Sorry, thought I could help. I better not even try.
In my experience, when I come across hiss, it's usually a preamp tube. Sometimes you just get bad ones. Try swapping some around and see if that makes a difference.
