Taking off pick up covers?
xjunjix
Post by xjunjix » Tue Sep 13, 2005 10:01 pm
just wondering how to take off the pick up covers...i just cant figure it out. i wanna take of the covers on my epi lp (just the bridge...i just wanted to look jimmy page-ish lol).
Post by Flames1950 » Tue Sep 13, 2005 11:18 pm
You have to unsolder the cover where it joins to the backing plate, then push it off the pickup. Some type of de-soldering method may help, be it a sucker or braid, otherwise you might have to heat the joint and pry the cover away from the solder CAREFULLY. Let it cool so you know it won't stick back to the backing plate, then go ahead and push it off.
Getting them off is easy, it's installing covers that sucks.......
Post by NY Chief » Wed Sep 14, 2005 12:43 pm
Be careful you don't clip a winding or your screwed. They may also be waxed. I pulled covers off an epi Explorer I got a deal on and spent hours cleaning the wax out of the bobbins. Just throw a Duncan or HOn in thing instead. It'll sound better and you'll still have the original.
Country Boy Shane
Post by Country Boy Shane » Wed Sep 14, 2005 6:40 pm
If it's wax, prepare for a mess man...
Just Feel it MAN! -Shane Gorski "Country Boy Shane"
www.flickr.com/photos/shanegorski
kurtsstuff
Post by kurtsstuff » Wed Sep 21, 2005 10:56 am
I've always just "popped" the solder by carefully...and I mean very carefully using a flat head screw driver and wedging it between the pickup and the cover right next to the solder and give it a slight twist and "pop" breaking the solder joint. of course....this does tweak the pickup cover but...it's the easiest and quickest way of removing it and I've never had any problems afterwards.....but....unless you've done it before...I take no responsibilty for suggesting this method...hehe ;)
