Taking off pick up covers?
Posted: Tue Sep 13, 2005 10:01 pm
by xjunjix
just wondering how to take off the pick up covers...i just cant figure it out. i wanna take of the covers on my epi lp (just the bridge...i just wanted to look jimmy page-ish lol).
Posted: Tue Sep 13, 2005 11:18 pm
by Flames1950
You have to unsolder the cover where it joins to the backing plate, then push it off the pickup. Some type of de-soldering method may help, be it a sucker or braid, otherwise you might have to heat the joint and pry the cover away from the solder CAREFULLY. Let it cool so you know it won't stick back to the backing plate, then go ahead and push it off.
Getting them off is easy, it's installing covers that sucks.......
Posted: Wed Sep 14, 2005 12:43 pm
by NY Chief
Be careful you don't clip a winding or your screwed. They may also be waxed. I pulled covers off an epi Explorer I got a deal on and spent hours cleaning the wax out of the bobbins. Just throw a Duncan or HOn in thing instead. It'll sound better and you'll still have the original.
Posted: Wed Sep 14, 2005 6:40 pm
by Country Boy Shane
If it's wax, prepare for a mess man...
Posted: Wed Sep 21, 2005 10:56 am
by kurtsstuff
I've always just "popped" the solder by carefully...and I mean very carefully using a flat head screw driver and wedging it between the pickup and the cover right next to the solder and give it a slight twist and "pop" breaking the solder joint. of course....this does tweak the pickup cover but...it's the easiest and quickest way of removing it and I've never had any problems afterwards.....but....unless you've done it before...I take no responsibilty for suggesting this method...hehe ;)
