A friend brought over his jcm900 2500 50 watt (el34). He was complaining of a sudden volume drop. I replaced the 2 el34s but when i went to bias I cant get it below 55vdc with the trim pot backed all the way down. The volume returned to normal but the tubes are redplating so hot that theyre literally smoking!
Could this be a bad ot or should I be looking at the bias supply (if I knew where to look
This is a 1990 model, the first year of the 900s I believe. Any help would be greatly appreciated.
