I have recently built an AX84 Hi Octane head (http://ax84.com/static/hioctane/AX84_Hi ... 101004.pdf) and had it working completely fine. Unfortunately I had placed the filter caps in an awkward spot and the chassis was not sitting flush, so I removed the filter caps and placed layed them flat to allow the chassis to sit flush. When I did this and turned the amp on, I heard no sound and I fried my 100ohm resistor (R2).
I checked all connections in the power section and everything appears correct. What could have gone wrong?
I replaced my filter caps and now the amp doesn't work! Help
Re: I replaced my filter caps and now the amp doesn't work!
Does your pilot light still go on? if not you may have shorted your HV windings. Ive done it before.
