Just a quick one.
Iv been drooling to test the shunt method biasing.
i understand that you need a good meter to do this.
Is this DVM that i have any good?
how do i test the meter or know if the meter is sturdy enough to take 400 plate volts and about thesame voltage at the center tap?
Which socket of the DVM should my test leads go to?
And at what setting should i be at to read current for the shunt?
I do know how to read the plate voltage and i understand they are not thesame when doing B+ to ground when checking for current.
