Page 1 of 2
I bought a Hot Plate.....
Posted: Thu Feb 12, 2004 3:53 pm
by VelvetGeorge
Last week. I've taken it to a few gigs and used it in the shop a bunch.
Very cool. Definately better than the power brake in the more attenuated settings. The extra features are sweet, too. I've got lots of ideas for the line out.
For the amount of attenuation I use (not more than 8dbs), it's not really better the the PB. Different, but I wouldn't say better. Where it really shines is at lower settings.
I took it apart (of course) and it's not a good candidate for modification.
Which is a shame, I'd like to add a second level control like I do on my PB's.
I'm going to try a wet/dry effects setup tonight at my gig. Using the line out on the HP. This should be fun!
Posted: Thu Feb 12, 2004 4:40 pm
by Country Boy Shane
The HotPlate is a doozy on the inside. Lots of quality made intricate work. I'm in love with mine.
Weber MASS
Posted: Fri Feb 27, 2004 8:56 am
by rjgtr
George,
You ought to look into a WeberVST MASS. It looks like it would be a modifier's kind of box. I have one and it allows the amp to sound good. Plus WeberVST offers all kinds of cool options, or you can buy the parts and roll your own! Plus he offers multiple Ohm selection options.
Richard
Posted: Fri Feb 27, 2004 2:16 pm
Doesn't the Weber have like 4 knobs... i don't know that is too complex for me. HA HA! :P
Posted: Wed Mar 10, 2004 11:17 pm
Dang my HotPlate gets insanely hot at -16dB settings. All that resistance could thaw me a chicken breast out of the freezer.
Posted: Thu Mar 11, 2004 4:47 pm
by bmf5150
george,
Talk to gnugear,he likes his mass better than the hotplate at low volumes..or even a better idea,build your own with the features you want.you could use the hotplate and mass as a building reference!
stan
Posted: Fri Apr 23, 2004 3:07 pm
by gnugear
I think the problem with the MASS is that it can't really take the pounding of a 100 watt Marshall. Sounds like a design flaw to me. Works great with my 50 watter though.
Yeah George, I think a Metroamp attenuator should be your next project!!!
Posted: Fri Apr 23, 2004 3:36 pm
by VelvetGeorge
You might want to take that up with Flames. He's voting for a JTM45 kit.
Posted: Fri Apr 23, 2004 6:08 pm
by Flames1950
Your call George. Flames may be broke soon.
Came home yesterday afternoon to water all over my basement, thank God the Marshalls and my Music Man have casters, but my freakin' 1966-very-clean-Fender Bassman was sitting on wet carpet. The water hadn't made it to the '67 Bandmaster, but man was I pissed. I snuck home today while I was running errands to check things out and the same thing had happened again (I'd moved the Bassman) so I get to call out the sewer guys and see what the hell the deal is. Should be a simple cleanout of the lines but you never know until the "pros" try to hose you out of a load of cash. Last plumbing job I had done turned into a $3000 nightmare of digging up my yard and replacing the whole line into the house. :x :x :( :(
Posted: Fri Apr 23, 2004 6:11 pm
by Flames1950
PS Shane, the knobs on the MASS are almost all for the DI output. If you're using it as an attenuator the only knob you adjust is the speaker output volume.
But it won't hack it with a raging 100watt Marshall. Only highly recommended with 50 watters. Which I guess leads full circle back to that JTM45 kit, George......funny how it all ties together like that. :D
Posted: Fri Apr 23, 2004 10:55 pm
Yea that is a good point! Oh man, check out this reply from Ed DeGenero at THD about my HotPlate. I'm sorry, but i think i know how to hook this baby up by having used it 2 years already!
What you describe I'm asked about once a day. This happens when the Hot Plate is hooked up backwards. Swap the cables from in to outpu in the Hot Plate and it'll be fixed.
On Apr 14, 2004, at 11:34 AM, Shane Gorski wrote:
Hello fellas,
I've been a loyal THD 16ohm Hotplate user for about 2 years now using it to hush my '69 Marshall SuperLead into my 4x12 cab loaded with G12H-30 watters @16ohms. Everything was going good with my head set on 16ohms and the cab in mono was on 16ohms. However, the time came when i wanted to upgrade my setup so it included another 4x12 cab at 16ohms.
I e-mailed you guys before about doing this and you said that ideally i would have to get an 8ohm HotPlate but that there was another way around it. You guys told me that if i set my amp on 8ohms and wired it to the HotPlate with 2-16 ohm cabs attached that there should be no problems. On the other hand, i've think i've noticed something real fishy.
When i'm running my amp at full volume and have the HotPlate at -16dB for small clubs with my new setup, at about 20 minutes through my set the volume of my whole rig totally divebombs and i have to set the HotPlate up a notch to -12dB which can be too loud for the situation at times. I don't know what the heck could be doing this. I was hypothesizing something around having a tiny power surge at the time and the HotPlate didn't like it, but turning it to -12dB really kind of showed that up. Do you think that the HotPlate could be overheating since its at such a high load? Either way this is definitely not cool. I sure hope this isn't damaging my new Mercury Magnetics Output Transformer that i paid so much money for!
If you can help me out as fast as you can that would be fantastic.
Thanks gentlemen,
-Shane Gorski
Re: I bought a Hot Plate.....
Posted: Sat Apr 24, 2004 12:29 pm
by dad99_2000
VelvetGeorge wrote:Last week. I've taken it to a few gigs and used it in the shop a bunch.
What kind of mods do you perform on the powerbreak??
Posted: Sat Apr 24, 2004 1:00 pm
by flemingmras
George performs a mod that makes it "gig ready". Basically it's a second stepping switch that he adds. You set one for your rhythm volume, then you set one a few clicks higher for your solo volume, then you can footswitch between the two so that your solos cut through. There's even a dual color indicator LED to let you know which mode you're in! WAY cool mod! I tried it out when I sat in with George's band Jedi Mind Trip and it totally works great!
Jon
Posted: Sat Apr 24, 2004 1:14 pm
Damn you guys! I wish i could do a mod like that on my HotPlate! :? ARRRRRRRRRRRRRRRRRRRRRRRRrrrrrrrr
Posted: Sat Apr 24, 2004 9:12 pm
by dad99_2000
So How can I do this with mine????
