Selling a Maxon Stereo Chorus. It's in excellent shape. Very lush sounding chrorus. Works great just no longer using it. Does not come with the original box or a power supply.
Below is (a lot) of information from the manufacturer:
Maxon CS550 - $110
The Maxon Vintage Series CS550 Stereo Chorus Pedal was designed in conjunction with professional guitarists and offers an entire range of unique chorus effects! The CS550 Pedal has Rate, Depth and a Delay Time control that varies the modulation time of the effect. True Stereo outs allow for mono, stereo, or inverted mono outputs. Rear-mounted Mix control blends dry and effected signals for improved low-end response (perfect for use with Bass Guitar). Uses Panasonic MN3207 IC chip for the ultimate analog tone!
Created for the discerning audiophile, Maxon Vintage Series effects pedals offer the highest construction and sound quality available in a compact pedal format. Hand made in Japan by experts with more than 30 years experience in the field, Maxon Vintage Series effect stompboxes use only the finest components available to achieve the most transparent, noise-free, full-frequency performance possible. The Maxon Vintage Series--your quest for the ultimate tone ends here.
Features
Unique chorus effects
True Stereo outputs
Mix control
Panasonic MN3207 IC Chip
Hand made
Maxon CS-550
