Echoplex EP-3 EP-4 serial numbers
AtomicChunk
Post by AtomicChunk » Mon Nov 12, 2007 11:51 am
Anyone know when the sreial numbers end for the EP-3's and start on the EP-4's?
T.J.Fuller
Post by T.J.Fuller » Tue Nov 13, 2007 9:43 am
Serial # 28591 ends it for the Ep-3 Models
but, I couldn't tell you anything about the Ep-4 units and how the serial numbers start or end.
Hope this helps.
AtomicChunk
Post by AtomicChunk » Tue Nov 13, 2007 10:52 am
T.J.Fuller wrote:Serial # 28591 ends it for the Ep-3 Models
Hope this helps.
I bought one in the 3 range. But it looks exactly like an EP-3, nothing different. I'm not sure how to distinguish an EP-4. :?:
T.J.Fuller
Post by T.J.Fuller » Tue Nov 13, 2007 10:59 am
You can go to www.schematicheaven.com
All models of the Echoplex (schematics) are listed in the effects section.
If you need an echoplex manual, just PM me your e-mail address.
I have one I can send in PDF. format.
It looks like the download section for manuals is no longer up at Schematic Heaven.
AtomicChunk
Post by AtomicChunk » Tue Nov 13, 2007 11:15 am
T.J.Fuller wrote:You can go to www.schematicheaven.com
Here is a photo of it:
My email is below, thanks! 8)
Image[/url]
AtomicChunk
Post by AtomicChunk » Tue Nov 13, 2007 4:17 pm
http://www.schematicheaven.com/effects.htm
psychodave
Post by psychodave » Tue Nov 13, 2007 7:30 pm
looks like an EP-3
T.J.Fuller
Post by T.J.Fuller » Tue Nov 13, 2007 7:45 pm
...yeah I was going to e-mail him about that!
Isn't the ep-4 box an army greenish color??
AtomicChunk , did you get the serial correct?
move your delay slider to the right and look thru the gap in the center.
AtomicChunk
Post by AtomicChunk » Tue Nov 13, 2007 11:36 pm
Yup, 33721, no doubt about it. I've been trying to get a pic up on my site but am having problems.
Strat78
Post by Strat78 » Wed Nov 14, 2007 1:07 am
I just bought an Ep-3 that is in the #32,750 serial range and it is definitely not an Ep-4.
Here is a shot of an Ep-4. I had one when I was a kid and I remember it with little fondness. Incidentally I sent my Ep-3 off to Orbit Electronics last week for an overhaul, should get it back in a month or so. Anybody use Orbit here?
AtomicChunk
Post by AtomicChunk » Wed Nov 14, 2007 9:12 am
Yea EP-4's seem to have all that extra stuff. I assume there just isn't a manual available in the highest serial range.
I want to send mine somewhere too and pick up a few tapes.
:idea: :?:
Myopic Void
Post by Myopic Void » Wed Nov 14, 2007 3:46 pm
I have 3 units EP2 last revision (tube model green box), Maestro EP3 serial 9888 2nd revision and Maestro EP3 #2 serial #20,162 3rd revision.
Ep3's start at 9065 I believe and go to appx 9450 for the first revision. 2nd Revision starts after 9450 my #9888 falls into the second revision that ends arround appx 12,500. I am going to guess 9888 is 71-72???
Looking at all the EP3 schematics it seems revision 2-3 have only one difference I can find. My #1 #2 EP3's sound different in spite of the same circuit...one is very bright and one is very dark. I cannot understand why though. It would nice to get them a little closer in sound.
Is there a way to cross serial numbers to exact years? Anyone?
Cheers,
Eric
jbzoso2002
Post by jbzoso2002 » Sat Nov 17, 2007 4:46 pm
i wish i knew i would like to date my 2 ep3's
in my avatar the one one the left is 143xx and
the one on the right is 285xx. one thing is for sure
these things sound great. ill never use any other
echo unit ever again :shock:
jimmy 8)
Myopic Void
Post by Myopic Void » Mon Nov 19, 2007 1:33 pm
jbzoso2002 wrote:i wish i knew i would like to date my 2 ep3's
jimmy 8)
I agree....at least you know your 28xxx is one of the very last and both of them are the third revisions. That narrows it a little bit. My new 9888 EP3 is around the 800th made which is pretty damn early :D guessing circa 70/71 I just picked this 9888 EP3 up from a client for one bill :shock: It is almost mint and had the original footswitch (RARE) instructions and papers with it :shock: The guy never used it! I have had my #1 EP3 since I was in High School, it is the only effect I use unless I switch it out for the tube EP2.
For depth and more complex nuances the EP2 cannot be beat, but the EP3's have a character I dig as well.
Cheers,
Eric
Tazin
Post by Tazin » Mon Dec 10, 2007 8:25 pm
For a rough date of manufacture you could read the date codes on the pots, and the serial number on the motor.
