Dax-The-Ax
Post
by Dax-The-Ax » Wed Mar 09, 2005 12:04 am
Post
by Flames1950 » Wed Mar 09, 2005 8:24 am
......weber silver bells........weber silver bells..........
........iwishmygoddamsoftwarewouldworksoicouldpostaclipforyou...........
Billy Batz
Post
by Billy Batz » Wed Mar 09, 2005 9:45 am
....with some 1230-55hz...
Hassan Chop
Post
by Hassan Chop » Wed Mar 09, 2005 6:04 pm
I have an Ampeg cab with those in it. It sounds great with a Laney Tony Iommi signature head I used to have and it still sounds great with my Carvin X100B that I use for clean tones. And it even still sounds good when I turn that Carvin all the way up (on the clean channel) and get that AC~DC-style mild-but-nasty-sounding (in a good way) crunch. I tried plugging my SLP re-issue rig into that cab and it didn't sound too great.
What kind of amp/guitar/pedals are you using with those speakers?
I knew we should've taken that left turn at Albuquerque!
Dax-The-Ax
Post
by Dax-The-Ax » Thu Mar 10, 2005 10:12 am
Les Paul or SG Standard with an EQ pedal for Lead boost straight into the Marshalls. It's funny, My 76' 2203 came back from getting a new PTP and a Dagnall Clone OT and it just kills! Now, my 50 watt model 1987 just doesn't sound the same to me. I guess i have to get a 100 watt 1959 now!! Or build one!!
Where is the best place to get the Webers?
Post
by Flames1950 » Thu Mar 10, 2005 11:48 am
Direct from Weber.
www.webervst.com
I don't know of any other way to get 'em. Careful though, he has
WAY too many speaker choices, you can get lost quick.
Dax
Post
by Dax » Thu Mar 10, 2005 12:01 pm
Flames, which silver bells are you using?
Post
by Flames1950 » Thu Mar 10, 2005 1:45 pm
The 30 watt ceramics. They put out strong enough lows and mids that they started my '94 1960AX cab rattling and vibrating on certain notes, so I had to put two RI Greenbacks back in that cab to shut it up. Too bad, the midrange honk and nice soft highs of four of those ceramic Bells in a cab is AWESOME. You know how some pepper sauces make your throat feel like it's choking up when you breath in? THAT'S how thick the mids on those Bells are, it's absolutely beautiful. Highs are nice and crisp but not obnoxious like new Greenbacks can be. Lows are solid but not too sledgehammer-y.
Since you have some 100 watt Marshalls you might go with the 50 watters though.
Dax-The-Ax
Post
by Dax-The-Ax » Thu Mar 10, 2005 7:43 pm
Boy, i checked out the Weber site, someone is gonna have to give me an exact model number speaker. Those dudes have alot of shit!!
Dax
Post
by Dax » Thu Mar 10, 2005 10:23 pm
How much dope do you guys like? Ha Ha Ha!!!
Seriously though, how much. I want crunch city!!!!
Dax
Post
by Dax » Thu Mar 10, 2005 10:26 pm
Another question, i was always told that running your amp at 4 ohms is more powerful than 16 ohms. So should i not get 16 ohmers?? Most of my shit now is 8 ohms.
jj jafar
Post
by jj jafar » Thu Mar 10, 2005 11:04 pm
dax i e-mailed you my address,and by the way i have 2 30 watt silver bell and 2 30 watt blue dogs with very little use on em.16 ohms and both ceramic,i may be willing to sell em.jason
Post
by Flames1950 » Thu Mar 10, 2005 11:28 pm
Dax wrote:Another question, i was always told that running your amp at 4 ohms is more powerful than 16 ohms. So should i not get 16 ohmers?? Most of my shit now is 8 ohms.
That may be true with solid state, but with a tube amp you're using less of your output tranny's secondary winding for a four- or eight- ohm setting. Sixteen ohms uses the full tranny winding. Some guys claim you can hear a difference and the sixteen is meatier. (Of course they have to set it to eight for a full stack......)
Besides, four sixteen ohm speakers can be wired for either sixteen or four ohms. Hence the JCM900 switching plate.
Post
by Flames1950 » Thu Mar 10, 2005 11:30 pm
Oh, and for "crunch city" you'll probably want at least moderate doping. My Bells and Greenbacks are doped (the Greens more so than the Bells) and I can still wreak cone cry out of them with my Strat. My Les Paul is pretty smooth since the humbuckers aren't as percussive.
