Fulltone '69
- thunder970
Fulltone '69
Has anyone tried one? I'm looking to run it through the clean on my 900 100w. Getting natural OD through this amp with 4-V30's is killing me in the house.
- thunder970
Fuzz sounds horrible on a clean amp. I can barely think of one example of someone using one that way on record. Theres a few but there all pretty nasty sounds. Maybe Hello I Love You with that really harsh in your face fuzz sound. There has to be at least a little gain there. You can tell on record when someone like Jimi or Page had the amps a bit too clean because the fuzz is really spitty and harsh and kind of square wave sounding. Ive had great success running a fuzz into a slightly driven OD pedal. Fuzzes clean up with the guitar volume knob to the point where at times I dont know what I like better. My amp backed off without the fuzz or my fuzz on and backed off. Adds kind of a clarity and gets things even cleaner with the volume knob.
- thunder970
The more I listen to hendrix the more I think he used his fuzz almost all the time. When I use a fuzz I have the amp on 6, fuzz at 1 o'clock and then roll volume on the guitar down to clean it up. Sounds really good. And I agree that it sounds terrible through a clean amp.
I think a clean boost might be more of what you're looking for ... or an eq pedal?
Gear:
'73 Super Lead
'70 Basketweave
'73 Super Lead
'70 Basketweave
- thunder970
Ok, I'm looking for something that will give me the sound of my little ga-5 les paul jr cranked. I get good drive from my 900 head on channel 1(clean channel) with the gain about 3/4 up. Problem is its weak at low volumes but when I get it cranked 6-8 master it has big nuts. But that is ridiculous loud. My neighbors can hear from inside their house
. I would just like a quality overdrive pedal. I've tried Boss sd-1 and it just thinned the shit out of my tone. I want a no tone sucking pedal with some balls.
I dont want to blaspheme or anything but for really low volume practicing I havent found anything better then both my Tech21 Trademark 10 and the Roland/Boss Micro Cube is actually pretty outstanding for a $150 SS amp. They also are great for making recordings DI. If your anything like me you cant get any kind of volume going at home.
- thunder970
- Country Boy Shane
I have a '69 pedal. This is definitely a pedal built for vintage Marshall plexi's and Fender's. Like others have said, it sounds like crap on a clean amp.
I run my '69 Repro. SuperLead at 6 on the high treble with these other settings...
Presence:4
Bass:5
Treble:7
The '69 is set at
Volume: 12 o'clock
Bias: 10 o'clock
Contour: DIMED!
Fuzz: 2 o'clock
I can run my LP on full volume and still have sweet control of my notes. Thank god for the bias control on this pedal too!
Presence:4
Bass:5
Treble:7
The '69 is set at
Volume: 12 o'clock
Bias: 10 o'clock
Contour: DIMED!
Fuzz: 2 o'clock
- Country Boy Shane
- thunder970
I don't think there is a such thing as perfect tone, lets be honest. I have seen where someone has modded every amp even plexi's. I think it's just finding a sound that you like. I found it in my 900, yes 900 DR 4100!! but it has to be cranked and I use just a little gain on the classic channel. I know, hotplate.but then it will lose some of what I like. I just need to get in a band where I can use it. as you say shane " not being in a band sux"
- dosmun
