Re: Phaser suggestion
Posted: Sat Jul 19, 2014 1:50 pm
It adjusts the center of the sweep. You will get a lower or higher sweep depending on where it's set. Mark where i'ts set and experiment.
The place for vintage amp discussion.
https://forum.metropoulos.net/
I have the same type, early block logo. got it off CL for $10, they said it didn't work or was cutting out. Switch was bad, now I like it better than any of the others I have had, sans a true script logo that this one sounds the same.Leotis wrote:I just got a '77 or '78 Block logo/Script back Phase 90 and to my ears it NAILS the early VH phase sound. I got it for less than the 1974 Handwired RI would've cost new. Granted, it's lacking the AC adaptability, LED, true bypass, etc...but it's built like a tank and sounds incredible. The subtlety is there, the note definition remains intact...I have NO complaints at all.
From what I understand, this is the exact same circuit as the original script logo. I think there was a feedback resistor or something added to the original stock circuit around this time, which usually results in a bit of a mid hump, but mine doesn't have it.
Yeah, I wish more people would realize that truth!Megaro wrote:I think results really depend upon your signal path and gear.
